Ignition Cable clamp
Mike Whisky
PostPosted: Sat May 17, 2008 10:38 am    Post subject: Ignition Cable clamp Reply with quote
Who knows where I can get two of these ignition cable clamps (for three cables)!
Michael
Zuerich, Switzerland
 Filesize:  103 KB
 Viewed:  343 Time(s)
RV-10 builder (flying)
#511
pitts_pilot(at)bellsouth.
PostPosted: Sat May 17, 2008 11:01 am    Post subject: Ignition Cable clamp Reply with quote
I don't know a source, but you can take a plain ADEL clamp (a 1 1/4"
should do it) and remove the rubber part. Put a screw through the hole
and tighten up a nut. Place a 3/8" thick piece of 'something' in the
clamp and squeeze in a vise to make the clamp oblong. Replace the
rubber part and you should have a usable clamp.
Linn
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?p=183556#183556
http://forums.matronics.com//files/zndkabelklemme_113.jpg
Albert Gardner
PostPosted: Sat May 17, 2008 11:55 am    Post subject: Ignition Cable clamp Reply with quote
Are you thinking of the Engine Baffle Ignition Wire Seals like on aircraft
Spruce cat/ page 272? Or something else?
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
PostPosted: Sat May 17, 2008 5:52 pm    Post subject: Ignition Cable clamp Reply with quote
Duh!!! Good question!!!! If he is looking for the baffle feed-through
clamps ..... makes my suggestion seem pretty stupid!!!
But then again, if someone is looking for ignition clamps that attach to
the valve covers ..... Bingo!!!
Linn
do not archive!!
Albert Gardner
Yuma, AZ
Mike Whisky
PostPosted: Sun May 18, 2008 1:37 am    Post subject: Re: Ignition Cable clamp Reply with quote
Linn,
I I am looking for the ignition clamps that attach to
the valve covers as you said the Adel Clamp modification is one way. However I wonder if there are the clamps for one and for two cables there must be also some out there for three did all six cylinder engine owners manufacture them themselves?
Michael
#511
PostPosted: Sun May 18, 2008 5:37 am    Post subject: Ignition Cable clamp Reply with quote
Linn,
Another good question!!!! Most all engines come with an ignition
harness and those clamps, and I've seen clamps that were pretty ragged
..... even missing the plastic and they put electricians tape on the
wires for anti-chafe!!! If you really want the 'real' clamps, then I'd
start looking at the magneto manufacturers themselves. I have a
downloaded Aircraft Spruce catalog on my workshop computer, but can't
get it to download on this one. The clamps may be available thru Spruce
...send them an email. I suspect that with a long ..... really long
... distance phone call and shipping it may be easier for you to make
your own.
Linn
Michael
#511
http://forums.matronics.com/viewtopic.php?p=183632#183632
