pj.ladd(at)btinternet.com Guest
Posted: Sun Mar 05, 2006 9:33 am Post subject: T6s on water |
Hi All,
sorry my post `Dont try this at home` didn`t work out.
The pics which should have accompanied it showed 4 T6`s apparently landing on water with each one trailing a wake. The second shot taken from water level showed that there were no floats but each T6 was just touching the surface of the water with its wheels. All part of a South African display teams show which has just been cleared as `safe` by the authorities. That reall is accurate flying.
Unfortunately I have deleted the pic now but if anyone has got it,. put it on.
Cheers
Pat
Bob Dalton
Posted: Sun Mar 05, 2006 10:17 am Post subject: Re: T6s on water |
Pat and all,
Here is a picture of the T6's on water.
Bob Dalton
75.4 KB |
436 Time(s) |
_________________ Bob Dalton
Manteca, Ca.
wiserguy@comcast.net |
Bob Dalton
Posted: Sun Mar 05, 2006 10:27 am Post subject: Re: T6s on water |
Gang,
Here are two more of the T6's on water.
Bob D.
53.33 KB |
433 Time(s) |
62.75 KB |
430 Time(s) |
Manteca, Ca.
Eugene Zimmerman
Eugene Zimmerman
flht99reh(at)netzero.net Guest
Posted: Sun Mar 05, 2006 2:14 pm Post subject: T6s on water |
I don't know Bob, I'm gonn'a want to check on the truthorfiction site. They
look pretty fake to me. To perfect, if you know what I mean.
Amused in Ohio Ralph
edchmiel(at)mindspring.co Guest
Posted: Sun Mar 05, 2006 7:30 pm Post subject: T6s on water |
Those aren't doctored pics. There's also video of it. Have seen pics of
other aircraft doing such also.
Ed in JXN
JetPilot
Posted: Sun Mar 05, 2006 8:13 pm Post subject: Re: T6s on water |
I think they are real. I have a friend that used to do the same thing in a 172 . Its dangerous, but at that speed the wheels act like skis, it does not take much contact area on water at 100 knots to generate a lot of lift. Just fly very smoothly down on a smooth lake, and let a LITTLE bit of weight on the wheels. Its dangerous, and its hard, but with enough skill it can be done Just look at the guys that water ski with bare feet, if you go fast enough you dont need skis, almost any surface will do....
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
rap(at)isp.com Guest
Posted: Sun Mar 05, 2006 8:55 pm Post subject: T6s on water |
We had a Brezzy that use to do the same thing hydro plane on an area lake.
Since it looked like an ultra light to the gen public, and I was the only
one in the area flying an ultra light. You can guess my surprise when a car
with FAA on its door showed up at my house. Luckly my plane was down with
and eng replacement and I could prove it was not me.
Posted: Mon Mar 06, 2006 5:49 am Post subject: T6s on water |
Thats the pic. Isn`t that incredible? Thanks Bob
Pat
