5 minute limit
Gilles.Thesee(at)ac-greno
PostPosted: Sun Mar 05, 2006 8:34 am    Post subject: 5 minute limit Reply with quote
Simon Smith a crit :
I've scoured all the books but I have a question to which I cannot find the
answer.
Assuming you have run at 5800rpm for 5 minutes and then reduced power, when
can you increase again? Clearly it is not a 5min total for the whole life
of the engine, and I doubt that the other extreme of simply reducing to
5500rpm and immediately going back to 5800rpm applies either. Clearly the
answer lies somewhere in between but where? Once per hour? Once per engine
start? Once per TCU power-up? Something else???
Hi Simon and all,
Good question indeed.
We chose to adopt once per takeoff.
And I retard to 100% power as soon as I'm airborne and climbing.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
paul.mcallister
PostPosted: Sun Mar 05, 2006 10:52 am    Post subject: 5 minute limit Reply with quote
Simon,
I know that this doesn't answer your question, but, the need for the 5
minute boost is very infrequent. I find on my Europa that I tend to use it
on grass strips of 1500 feet or less when I am at MUW or, when the density
altitude is greater that 5000' and I am at MUW. I find that I only need it
for 2 minutes at the most when I do kick it in.
It does make quite a difference, much more than I would expect for a 15 HP
boost and its sure nice to have that extra bit under the hood if you ever
need it.
Paul N378PJ
jthursby(at)tampabay.rr.c
PostPosted: Sun Mar 05, 2006 1:00 pm    Post subject: 5 minute limit Reply with quote
I left Lakeland with the company demonstrator once to see what it would do.
On a cool morning with about ten gallons fuel and no baggage. I put the
throttle to the stop and pulled to 67 or 68 mph after takeoff and left it
there until the computer said it was time to stop and opened the waste gate.
At 11,050 feet agl was the top of the climb and it did it in 8 minutes 30
seconds. That's around 1,330? average climb rate per minute. Not too bad.
The red light comes on at five minutes regardless of whether the airbox is
over temperature or not, but the boost stays the same unless it over temps.
Remember, Ivan used to run the Sun 60 race in full boost for the whole 60
miles! And then Pete Clark would fly his acro routine later on the same
day.
Jim T
