gary-n-dorothy(at)tctwest Guest
Posted: Sat May 17, 2008 11:12 am Post subject: Ivo inflight adjustable props |
[b]One that I bought on EBay from eagleaviationllc , in Oshkosh had a bad motor and some stripped gears in the reduction unit.
I don't think this is a common fault as long as Ivo's recommended procedures are followed.
You might ask Ron at Ivo, perhaps this prop was installed incorrectly , or what could cause this.
Ivo was very helpful in getting me the correct setup, as the EBay prop was not the correct unit for my installation on a 582 Rotax.
I went with the ground adjustable and understand I can upgrade with a In flight adj. package should I wish in the future
By the way, Service bulletin #17 states, "that the ENGINE side rail mount must not be used with a 3.47 or 4.0 to 1 gearbox. " Does any one know why ? What would one do if they wanted to use a 3.47 gearbox in the way of mounting the engine ? Any known fixes? I got a new E box with a blue head engine and would like to use the new stuff when I decide to do the 300 hr thing.
Gary Glasgow
Kitfox lll
#1165
N4276M
[/b]
dave
Posted: Sat May 17, 2008 3:29 pm Post subject: Re: Ivo inflight adjustable props |
Gary, What ratio gear box do you have?
I run 3 to 1 now and have tried 2.62 and it gave worse performance. I was actually thinking of trying a 3.47 or 4 to 1 this summer.
I have over 450 hours on my 582 right now since June 06 and never been apart yet.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
