densing(at)carolina.rr.co Guest
Posted: Wed Jan 04, 2006 9:02 pm Post subject: Garmin 296 |
Does anybody know if the power cord of the Garmin 295 with the NEMA output wires is compatable with the 296?
Dale Ensing
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
willfly(at)carolina.rr.co Guest
Posted: Thu Jan 05, 2006 3:31 am Post subject: Garmin 296 |
You should be able to find out at Garmin.com.
Cappy
sportav8r(at)aol.com Guest
Posted: Thu Jan 05, 2006 9:10 am Post subject: Garmin 296 |
anyone know a way to adjust the contrast so the colors don't look washed out when viewed from the left? Mine looks great from the pax seat or straight on, but almost monochrome from the left seat. Changing display to night setting helps some, giving deeper colors, but not the same colors, shifted somehow...
dbreda(at)earthlink.net Guest
Posted: Thu Jan 05, 2006 9:29 am Post subject: Garmin 296 |
If there's a contrast adjuster, I haven't been able to find it and the
manual doesn't say anything about it. I have a hard time seeing mine
anytime due to glare. Anybody know there's a commercially-made glare
shield for it?
Dana
Posted: Thu Jan 05, 2006 10:25 am Post subject: Garmin 296 |
That's why they sell it with a swivel mount. So you can point it at you.
Cappy
Lenleg(at)aol.com Guest
Posted: Thu Jan 05, 2006 10:28 am Post subject: Garmin 296 |
Posted: Thu Jan 05, 2006 10:57 am Post subject: Garmin 296 |
I guess the thing is made to sit straight in front or to the left of the viewer. Mine's in my radio stack, in a Panel Dock, off to my right. I'd even settle for a way to flip the display upside down...
Posted: Thu Jan 05, 2006 10:58 am Post subject: Garmin 296 |
on the 296 that brings up the brightness and volume sliders
Posted: Thu Jan 05, 2006 2:53 pm Post subject: Garmin 296 |
Cappy
Tried that. No joy. That's why I thought I would ask the list. Guess I'll
give Garmin a call.
Dale
Posted: Thu Jan 05, 2006 3:33 pm Post subject: Garmin 296 |
That is the brightness not contrast.
Cappy
Larry(at)bowenaero.com Guest
Posted: Fri Jan 06, 2006 4:26 am Post subject: Garmin 296 |
I just hooked up my 296 with the wires you are describing and only used 3 of the wires. Power, Ground and Nav. The other 6 are for other than basic functions. Don't know what.
PS Larry, I cut the hole in the glareshield for the antenna. Looks good. Get well quick. If you need a ride home when you deliver NIFTY for paint let me know.
Cappy
Posted: Fri Jan 06, 2006 8:13 am Post subject: Garmin 296 |
Larry, thanks for your response on the 295/296 power/data lead.
