Hartzell prop and IO540D4A5
Goto page 1, 2  Next
dlm46007(at)cox.net
PostPosted: Tue May 13, 2008 2:59 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Did anyone have to adjust the low pitch stop on the prop from Van's to get the 2700 RPM? or was the entire adjustment in the governor?
ricksked(at)embarqmail.co
PostPosted: Tue May 13, 2008 5:24 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
David,
I don't know if this will help but this was the response I got from MT about setting the governor and low speed RPM.
Rick Sked
40185
"All P-860-( ) governors are basically the same. The - ( ) number only refers
to the control arm position and the max. rpm of the governor. To change the
control arm, loosen the 6 screws, turn the entire center portion to the
desired position, tighten the 6 screws and safety.
To change max rpm the set screw on the high rpm stop is turned
counterclockwise (out) to increase rpm and clockwise (in) to decrease rpm.
If there is not enough adjustment possible ( 1 turn = 25 rpm) the control
arm must be reset on the spline one notch at the time.
All this can be done on the plane.
To have MT Propeller USA, Inc. modify the governor max. rpm would cost
approx. $100.00, unfortunately the control arm position must be adjusted on
the plane"
d_emond(at)mweb.co.za
PostPosted: Tue May 13, 2008 10:54 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
If memory serves me right I was only getting 2500 RPM. I had to reset my arm one spline. I made a reference mark, took the screw adjustment up to close to the reference mark, and then screwed it out each flight, until I got to the desired RPM.
Dave Emond
raddatz
PostPosted: Tue May 13, 2008 6:12 pm    Post subject: Re: Hartzell prop and IO540D4A5 Reply with quote
I believe all the 10's I built where around 2550-2600 out of the box, I just mark the arm and shaft and move the arm one spline.
lessdragprod(at)aol.com
PostPosted: Tue May 13, 2008 8:41 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
If Van's Aircraft sold the P-860-5 governor for the wide deck Lycoming IO-540 engine, you wouldn't even be having this discussion.
The P-860-3 governor is for the narrow deck Lycoming IO-540 engine, which has a different gear ratio to the front mounted governor.
Jim Ayers
PostPosted: Tue May 13, 2008 9:01 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Yup.....Jim has the correct info in that!! No surprise. Curious.....How many narrow decks are out there?...ummmm NOT MANY!! It's a Dutch think I think, and an ignorance thing on us builders...not so ignorant now though.
Rick Sked
40185
Dick Sipp
PostPosted: Wed May 14, 2008 6:13 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Jim:
Is re-indexing the arm on the govenor an as others have mentioned a factory acceptable adjustment?
Dick Sipp
PostPosted: Wed May 14, 2008 7:34 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Dick,
It is...Here as I posted before is the response from MT USA direct from their resident expert and this guy really knows his stuff.
Rick Sked
40185
all P-860-( ) governors are basically the same. The - ( ) number only refers
the plane
Best Regards,
Juergen Zahner
mt-propeller USA, Inc.
ph: [url=callto:+1386-736-7762]386-736-7762[/url]
fax:[url=callto:+1386-736-7696]386-736-7696[/url]
Juergen.Zahner(at)mt-propellerusa.com
www.mt-propellerusa.com
PostPosted: Thu May 15, 2008 8:09 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Hi Dick,
I received the following comment from MT Propeller in Germany.
"(The) Best way is to send it (the governor) to MT USA as they do it (the adjustment) on the test bench. UPS Ground is not expensive and the better way. In the operating & Installation manual of the governor (it) is stated on page 12 that the modification must be done at an authorized service shop."
Additionally, because of the spring loading, the MT Propeller factory is concerned about the customer loosing track of the position of the splined shaft when the control lever is removed.
Jim Ayers
dlm46007(at)cox.net
PostPosted: Thu May 15, 2008 8:27 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
before indexing mark the spline and the handle. and when changing the handle hold the spring.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lessdragprod(at)aol.com
Sent: Thursday, May 15, 2008 9:05 PM
Subject: Re: Re: Hartzell prop and IO540D4A5
Hi Dick,
Jim Ayers
dlm46007(at)cox.net
PostPosted: Thu May 15, 2008 8:34 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
The MT propellor rep in FL provided info to do it on the aircraft.
Hi Dick,
Jim Ayers
PostPosted: Fri May 16, 2008 6:15 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
The MT Propeller factory in Germany recommends sending the governor to the MT Propeller rep in Florida. (This is a what is best for everyone answer. Everyone is assured of getting a governor set up for their engine.)
The MT Propeller rep in Florida provided information for those people that want to try to do this themselves. As they are getting the aircraft ready for Phase 1 testing. (Like there's nothing better to do? Smile )
Now we've both said it twice. Smile
Except, why is Van's Aircraft STILL only selling the MT governor for the NARROW DECK IO-540 engine? Van's Aircraft only sells new WIDE DECK IO-540 engines.
Jim Ayers
pascal(at)rv10builder.net
PostPosted: Fri May 16, 2008 6:45 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
I want to know Why they are still also ONLY selling the 2 blade Hartzell prop when Hartzell has composite blades that work just as well if not better (at a higher cost)..
granted none of this is good for MT but I would like to see the composite Hartzell and give Jim the business directly for MT, which one needs to do anyway.
Oregonians, walk over and put some pressure on Van's to update their prop selections.. please!!
Pascal
From: lessdragprod(at)aol.com (lessdragprod(at)aol.com)
Sent: Friday, May 16, 2008 7:10 AM
Jim Ayers
-----Original Message-----
Sent: Thu, 15 May 2008 9:28 pm
Subject: RE: Re: Hartzell prop and IO540D4A5
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com ([email]owner-rv10-list-server(at)matronics.com?[/email])] On Behalf Of lessdragprod(at)aol.com (lessdragprod(at)aol.com)
Hi Dick,
Jim Ayers
rv(at)thelefflers.com
PostPosted: Fri May 16, 2008 7:18 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Our EAA chapter took a tour of Hartzell last week. Although they wouldn’t say anything specific, they did hint that we would have more Hartzell choices from Van’s in the next month.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Friday, May 16, 2008 10:43 AM
Pascal
Jim Ayers
PostPosted: Fri May 16, 2008 7:56 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Thanks for the status Bob, that is great news! Maybe my constant e-mails asking for the consideration went somewhere afterall.
Pascal
Sent: Friday, May 16, 2008 8:15 AM
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Pascal
Jim Ayers
RobHickman(at)aol.com
PostPosted: Fri May 16, 2008 8:46 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
"I want to know Why they are still also ONLY selling the 2 blade Hartzell prop when Hartzell has composite blades that work just as well if not better (at a higher cost).."
You should have gone to the RV-10 dinner last weekend, I just happen to know who is testing the new 2 blade composite Hartzell prop on a RV-4.
Extremely smooth, much lighter, and it looks and sounds cool.
Rob Hickman
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
PostPosted: Fri May 16, 2008 11:12 am    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Haha, gone to a dinner 1000 miles away? .. you crack me up [img]cid:0789E2DF7C254D20A25FFEE39C3C668F(at)pascaldell[/img]. By the way, thanks for sponsoring it.
Any performance difference noticed? climb, cruise, etc.. with the composite prop?
Any updates (unofficially) on the DECK and future plans for it's expanded capabilities?
Thanks!
From: RobHickman(at)aol.com (RobHickman(at)aol.com)
Sent: Friday, May 16, 2008 9:43 AM
Rob Hickman
 Filesize:  1.31 KB
 Viewed:  13650 Time(s)
PostPosted: Fri May 16, 2008 12:34 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
In a message dated 5/16/2008 12:14:51 P.M. Pacific Daylight Time, pascal(at)rv10builder.net writes:
Haha, gone to a dinner 1000 miles away? .. you crack me up . By the way, thanks for sponsoring it.
Thanks!
I am still gathering data on the prop, should have it in another week or so. I am currently flying the flight director, autopilot interface, and weather. We currently have six full time engineers and four of them are only working on software.
Rob Hickman
 Filesize:  1.31 KB
 Viewed:  13653 Time(s)
AV8ORJWC
PostPosted: Fri May 16, 2008 6:25 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
At the Pacific NW RV-10 Builder Dinner, Rob Hickman was displaying his test bed Hartzell prototype 2 blade Scimitar II Composite prop on is RV-4. I am sure he is under a gag order but I stole a Hi-Res picture (which has been Matronic neutered here). The identification on each blade read "Des. No. N7605-2X.
Skunkworks NW
John C.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Friday, May 16, 2008 8:16 AM
Pascal
Jim Ayers
Rob's_Test_Prop.pdf
 Filename:  Rob's_Test_Prop.pdf
 Filesize:  399.76 KB
 Downloaded:  703 Time(s)
AV8ORJWC
PostPosted: Fri May 16, 2008 6:33 pm    Post subject: Hartzell prop and IO540D4A5 Reply with quote
Rick Sked, Deems Davis and Les Kearney all exceeded the 1,000 miles from home rule to make the dinner. The Hickman's were gracious hosting the event. All things are possible for the Fall get to gather.
Still LOL.
John
Sent: Friday, May 16, 2008 12:10 PM
Haha, gone to a dinner 1000 miles away? .. you crack me up [img]cid:image001.gif(at)01C8B78B.0C46E8D0[/img]. By the way, thanks for sponsoring it.
Thanks!
Rob Hickman
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
 Filesize:  1.31 KB
Goto page 1, 2  Next
Page 1 of 2
