Posted: Tue Jul 15, 2008 5:26 pm Post subject: Over filling during flight? |
Hi Guys,
July 14 Monday was perfect. I walked Toby our cat, then packed the
flight bag and went to the airport. After a lengthy preflight, the plane
was pulled from the hangar and I did a secondary walk around. All good,
the tower cleared my request for runway 5. I lifted off in a soft
downwind, but still short enough for traffic. I set course for Clinton
and climbed to 3000 ft. On the formerly flooded Mississippi, one could
see the river traffic moving again and a few recreational boaters.
Clinton airport was also visible 8-miles out. I passed over the airport
and entered downwind for 32. Good pattern work, but I flared a foot high
and just bounced the touchdown. I taxied in and parked to check
wheel-pants for damage. None was found, so after visiting with the FBO,
I taxied to 32 and took off, departed west. The header tank was less
than ¼ full so the left wing pump was turned on. Engine temps were good
for an 85-degrees ambient. EGTs 1370, oil 220, coolant 198, CHT 210 and
oil pressure was 48 psi. On turning south for the return, I called Quad
Cities approach, collected traffic and guidance and nearly forgot to
track the refill. The header was completely full when I turned off the
wing pump and centered the selector valve. I felt a chill down my spine,
because I didn't want to “overfill”. I worried that fumes from spilled
fuel could trace across the 601’s non-laminar wing to the exhaust pipe's
back draft and turn the plane into a “roman candle”. I couldn't smell
any fuel within the cabin. On landing, I taxied back and shut down.
Inside the header, fuel was 3-inches from the cap and the overflow tube
was dry. This is the tank's max fill limit. Very relieved, I put the 601
back in the hangar and drove home with this tidbit chewing on my mind.
Nice flight, but the wrong kind of adrenaline rush!
The question would be, is it possible to use the EIS to read the full
point of a common rheostat type tank sensor to set an alarm point?
Or, should one consider a blinking light that constantly runs when
either of the wing pumps is running.
Or, does anyone have a good "reminder" that the pump is running or the
tank is nearly full?
Thanks again,
Posted: Tue Jul 15, 2008 6:01 pm Post subject: Over filling during flight? |
Pillar Point Avionics offers an optical in-tank sensor that you could use.
Normally this is used to sense when a tank is emptying and the sensor
uncovered. But there is no reason why you couldn't use it to sense when it
becomes covered.
http://www.ppavionics.com/UFSTUFSAN.htm
Or you could just set a kitchen timer.
-- Craig
PS - I thought the advantage of a cat over a dog was that it didn't need
walking?
tjs22t(at)verizon.net Guest
Posted: Wed Jul 16, 2008 1:34 am Post subject: Over filling during flight? |
Go back in the archives and use "Pillar Point & Bill Morelli" as he uses one...do not archive
becomes covered.
psm(at)att.net Guest
Posted: Wed Jul 16, 2008 3:04 am Post subject: Over filling during flight? |
Hi Larry,
I've been mulling over your question about filling the header
tank. I didn't want to say anything because I really don't have a
complete solution to the problem. However, I have a different way of
looking at it that might help you.
My thought is to design some electronic control that allows the fuel
pump to operate only when the header tank has room for fuel. This
would allow you to automatically keep the header tank loaded without
any conscious effort on your part.
Such a circuit would need "Hysterisis" (sp?) which means it would
use different levels of fuel in the tank to turn off and turn
on. For example it might turn on when the tank is 1/4 full and turn
off when it is 9/10 full.
While such a control circuit is relatively simple to design, I'm
afraid my own experience is not up to the task. The problems are the
harsh environment of being in an airplane and the high power needed
to drive the fuel pump. My own experience was limited to circuits
working in the more benign electrical environment of the innerds of a
computer. That means I am not volunteering to do the design but just
suggesting the idea.
Good luck,
Paul
XL almost there.
At 06:23 PM 7/15/2008, you wrote:
| Quote: | The question would be, is it possible to use the EIS to read the
full point of a common rheostat type tank sensor to set an alarm point?
the tank is nearly full?
Thanks again,
raymondj(at)frontiernet.n Guest
Posted: Wed Jul 16, 2008 2:57 pm Post subject: Over filling during flight? |
Would it be practical to run the header tank vent back into the top of wing
tank so if the header gets full the excess is pumped back into the wing
tank.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
klaus(at)utdallas.edu Guest
Posted: Thu Jul 17, 2008 10:45 am Post subject: Over filling during flight? |
Hi Larry,
In the original configuration of my 601HDS, two on/off switches
controlled the pumping from the wing tanks into the header tank.
During the first 10 hours I found out that this was a terrible arrangement.
I overfilled the header tank in flight, something you have avoided so far.
This produced a very dangerous situation.
There are many ways to fix the problem,
as you can see from the suggestions by others. I opted for
a very simple solution. I replaced the on/off switches by
spring loaded switches that when released always snap back
to the off position, where according to convention
the switches point down. This arrangement forces me to hold
the switches up while pumping. Sensing the pressure of
the switches keeps my attention on the filling process.
If I have to attend to something else, I let go of the switches, and
the pumping stops right there. In 1100+ hours of flying,
this has worked well. During a cross country flight, I
typically pump up the header tank every 30 min or so,
which is done rather quickly. Actually, it gives me something
to do and reminds me to think about the fuel supply.
Happy flying,
Klaus
Posted: Thu Jul 17, 2008 11:19 am Post subject: Over filling during flight? |
Hi Klaus,
That's the simplest and most direct thing I've seen so far. Certainly
the easiest change to make
at this moment. Excellent idea!
Klaus Truemper wrote:
Hi Larry,
arrangement.
far.
Happy flying,
Klaus
grs-pms(at)comcast.net Guest
Posted: Thu Jul 17, 2008 2:27 pm Post subject: Over filling during flight? |
A big second to Larry's comment, re Klaus' solution to over-filling the
header tank. This is what one of my engineering profs would have called "an
elegant solution". No added weight, no added complexity, and if you do it
from the beginning, no added cost. I'm going to modify my still incomplete
601HD accordingly. Thanks, Klaus!
George Swinford
do not archive.
Posted: Thu Jul 17, 2008 2:44 pm Post subject: Over filling during flight? |
Greetings Klaus,
How have you integrated fuel management into your emergency restart
checklist?
Raymond Julian
Kettle River, MN
"Hope for the best,
Posted: Fri Jul 18, 2008 12:36 pm Post subject: Over filling during flight? |
Hi Raymond,
You ask:
restart checklist?
The checklist depends on the engine and the tank system.
In case of complete engine failure:
1. Trim plane for best glide speed. Unless there an is unusual situation,
the propeller of the Rotax 912, 912S, or 914 will stop
due to the high compression ratio
of the engine and the fact that the propeller is geared. For direct
drive engines, the propeller likely will be windmilling.
2. Pick out a landing site. Fly toward the landing site at optimal glide
speed.
3. If there is time for a restart atttempt:
3.1 (Here comes a controversial part) If this is a Rotax engine,
turn off the avionics since otherwise
the radios may be blown by surge voltages during the starting. (This nasty
aspect of the Rotax engine is not exhibited by direct-drive engines
that would be windmilling. In that case, the generator continues charging
and the starter is not needed in the restart attempt, a definite plus.
On the other hand,
a windmilling propeller has more drag than a stopped propeller, a definite
minus as far as the glide ratio is concerned. )
To prevent starting of the Rotax engine with avionics turned on, we have
it set up that the starter can be activated only if the avionics are off
(another controversial part).
3.2 In the case of a direct
drive engine with windmilling propeller, check the oil pressure. If it is
zero, the engine is cooked and it's best to focus on everything
else. (The Rotax engine does not provide that
clue since it will be stopped and will have zero oil pressure regardless
of the condition of the engine.)
3.3 Turn on the boost pump.
3.4 601s with centertank and wing tanks:
If fuel level in the main tank is low, activate and hold the transfer
switches (here is a disadvantage that they are spring loaded and must be
held.
On the other hand, if the switches are on/off, then forgetting later
that they have
been turned on may overfill the center tank and create an extremely
dangerous situation during an emergency landing.)
601s with two leading edge tanks: Switch tanks.
3.4 Open throttle halfway.
3.5 Crank engine.
4. If engine does not restart and there is time left:
turn off fuel supply to engine, turn on avionics again
if turned off before, and make emergency call on 121.5.
5. When over the emergency landing site, begin circling.
When about 1000 ft AGL, go for the landing. If this is an HDS, dive for
the landing area
and do not try to fly an approach pattern, since likely the attempt will end
short of the landing area (The message for HDS pilots to remember is
"Dive for the landing"). For HD and XL, the glide ratio is better and
one must
make sure not to come in too high. But if this is actually an airport, then
nevertheless dive for the runway and dissipate any remaining altitute by
forward slip.)
Here is one more thought. We take off from a familiar airport so many times
that we become quite sure that this will always be successful. Next time
you take
off and begin the climb, you may ask yourself repeatedly, as you
gain altitude, the question "If the engine quits right now,
where should I land?" It may be that you will have
think about this. Well, doing it now is be better that when the real thing
happens.
Happy flying,
Klaus
Posted: Fri Jul 18, 2008 1:50 pm Post subject: Over filling during flight? |
Klaus,
Thanks for the detailed reply. You bring up several things about a
geared engine I had not given any thought to.
I was curious where you put the pumping fuel to the header in the list.
I assume you hold the switches while you are cranking the engine, or perhaps
I should say I think I would. It makes sense to me now.
Thanks again for taking the time to reply.
Raymond Julian
Kettle River, MN
"Hope for the best,
Posted: Mon Jul 21, 2008 10:35 am Post subject: Over filling during flight? |
Hi Raymond,
Yes, the fuel transfer switches are activated while the engine is cranking.
A point I forgot in the previous list for engine restarting:
The most important steps should be taken before the engine has fully quit.
Here is a list that seems reasonable when the engine does run okay,
say is losing rpm or runs rough or stutters.
1. If there is manual mixture control, go to full rich.
2. Turn on auxiliary fuel pump.
3. Switch tanks if fuel is alternately taken from two tanks.
If there are a main tank and auxiliary tanks: check fuel level in main
tank and
begin transfer if not at max level.
4. If there is carburetor heat and there is even a remote possibility
of carburetor ice: Pull carburetor heat. It will take a bit of time
for the ice to melt and the engine to speed up again.
The ideal temperature for carburetor ice is 68 degF OAT since the
air temperature drops by 36 degF in the carb venturi. But this is
by no means a rule. I have had carb ice with a Lycoming engine
that is not very susceptible to that problem, on a clear day with
good visibility at 32 degF OAT. Make sure that this action
is taken without delay, since otherwise preheat
may no longer work.
5. Check the oil temperature. If the temperature is unusually low or
unusually high, then most likely the engine is cooked. This is the
best tool for diagnosing a failed engine. (I did not learn this as
a student pilot, but was told about this later by experienced pilots.)
6. Check the engine oil pressure. If it is very low or zero, again
7. (Rotax) Check coolant temperature. If excessive, engine will
fail shortly. Reduce power as much as possible while working
on landing site.
Happy flying,
Klaus
Klaus Truemper
Professor Emeritus of Computer Science
University of Texas at Dallas
Erik Jonsson School of Engineering and
Computer Science EC31
P.O. Box 830688
Richardson, TX 75083-0688
(972) 883-2712
www.utdallas.edu/~klaus
Posted: Tue Jul 22, 2008 7:44 pm Post subject: Over filling during flight? |
Thanks for the added info and suggestions.
Raymond Julian
Kettle River, MN
"Hope for the best,
