Need recommendations for work table
Max Johansson
PostPosted: Thu May 08, 2008 10:45 pm    Post subject: Need recommendations for work table Reply with quote
More about worktables:
Although not a requirement to have the table exactly horizontally level (only flat is required)
it helps to be able to use a water level. This later is true as well when assembling the rest
of your aircraft when the upper back of the 701 airframe is the reference surface.
Three more helpful things:
- use a cheap or sacrificial work table surface so you can drill into it without remorse
- clecos can be used with ad-hoc holes drilled in the table surface to keep anything in place
- having a few inches of table edge overhang really helps to clamp down anything you work on
regards
Max
Max
Max Johansson, Helsinki, Finland
Building a CH701SP-912S
on CZAW amphibian floats
