Landing the 701
george.mueller(at)aurora.
PostPosted: Wed May 07, 2008 5:27 am    Post subject: Landing the 701 Reply with quote
I have a question for those who have been flying their 701s for a while. For most of the other airplanes I have flown, the landings go like this: The mains gently kiss the runway, chrip chirp, and the nosewheel is held off and gently and slowly comes down as the energy dissipates. (Ok, that happens some of the time). When I land my 701, the mains touch down more or less gently, but the nosewheel immediately plunks down. The closest I have come to being able to hold the nosewheel off is to hold 3,000 RPM (with an 80hp rotax) all the way down final, and this gives me enough energy to hold the nosewheel off. This seems like a lot of power to carry into the flare. Is the three wheel plunkdown just the way it is? Is there something wrong with my rigging (incidence of horizontal stabilizer, etc)? I do have vortex generators on the elevator. I do not have a forward CG at all, as I have a BRS in the baggage compartment and a rotax up front. Does anyone have any tips? I am thinking of installing an angle of attack indicator to more precisely control things in the landing.
George in Milwaukee
N701GM 912UL 20hrs [quote][b]
dougsnash
PostPosted: Wed May 07, 2008 10:22 am    Post subject: Landing the 701 Reply with quote
George, sounds to me like you might need to increase
your approach speed a little(lower the nose during
final). This will give you a bit more energy to use
during the flair. You didn't mention what you were
using as an approach speed.
Take this with a grain of salt though as I am basing
this on general light plane expirience and not on
specific 701 expirience as I am currently still
building and have zero hours in a 701.
The Angle of Attack indicator or Lift Reserve
Indicator would probably be a big help in this
situation.
Doug MacDonald
CH-701 Scratch Builder
Canadian Ultralight flight instructor
down. The closest I
to hold 3,000 RPM
the way it is? Is
I do not have a
of installing an
George in Milwaukee
N701GM 912UL 20hrs
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
n801bh(at)netzero.com
Almost everyone who flies a 701 / 801 has this same observation. It must the geometry of the airframe to landing gear placement. My 801 does the same thing,, for short landing I carry alot of power, keep it nose high and as slow as I feel safe for the wind conditions and just expect the nose wheel to hit rather firmly... The current fix is the reverse the main gear and that puts the rear wheels farther forward making it less prone to slam the nose down but in the 801,s case you have to notch the gear to fit the attach bracket. If I reverse mine I would have to elongate those notches and that is something I don't want to do.
Tailwinds
Ben Haas
N801BH
www.haaspowerair.com
George in Milwaukee
N701GM 912UL 20hrs
1-List">http://www.matronics.com/Navigator?Zenith701801-List
tronics.com
www.matronics.com/contribution
_____________________________________________________________
Click for online loan, fast & no lender fee, approval today
dougsnash
PostPosted: Wed May 07, 2008 11:47 am    Post subject: Landing the 701 Reply with quote
Unfortunately, reversing the 701 landing gear won't
help as it is not a tapered part as in the 601 or 801.
Doug MacDonald
CH-701 Scratch builder
NW Ontario, Canada
I don't want to do.
Tailwinds
Ben Haas
N801BH
ggower_99(at)yahoo.com
PostPosted: Wed May 07, 2008 3:55 pm    Post subject: Landing the 701 Reply with quote
What I have learned in this years is that this condition (heavy nose wheel) is a bonus, is part of the stability of the airplane in the ground... desingned in the Zenith airplanes (for low hours a year pilots).
I have landed in some grass strips that are far from Golf course quality Smile and in the roll out or "fasterly" taxi the front wheel bounces... Could hit the tail if was more light loaded.
In the time I have flying ours (me about 80 of the total hours, others are my brothers) We have developed an instinctive way to hold the nose wheel up at roll out and then gentle let it go when the elevator is loosing force, most of the times it does not bounce, but on the other side, some of the bounces of the front wheel are capable of ashame me in front of pilots Smile
Saludos
Gary Gower.
Do not archive.
MacDonald Doug <dougsnash(at)yahoo.com> wrote:
[quote]--> Zenith701801-List message posted by: MacDonald Doug
Doug MacDonald
NW Ontario, Canada
--- "n801bh(at)netzero.com" wrote:
[quote] Almost everyone who flies a 701 / 801 has this same
rather firmly... The current Be a better friend, newshound, and [quote][b]
peterlthomson(at)gmail.co
PostPosted: Thu May 08, 2008 2:29 am    Post subject: Landing the 701 Reply with quote
I put my VG's under the elevator (www.stolspeed.com) and find I can hold the nosewheel off the ground on a fast taxi.
Occasionally I get the nosewheel plunking down or a 3pter, but most usually it is mains first and then the nosewheel in orderly fashion.
It took a while to get there as 701 quite different to the feel of larger GA a/c, etc. [quote][b]
321PT
PostPosted: Thu May 08, 2008 6:20 am    Post subject: Landing the 701 Reply with quote
You are right in holding power to keep the nose off. Without power you just sort of land and park it at the same time. Makes for a short landing though.
I fly my approach at 55 MPH with 3,000 RPM to touchdown. It help makes the squeaky landings. If I am flying at gross wt. my RPM will be as high as 3,200. This makes for a more "conventional" landing.
It doesn't sound like you have anything wrong with your rigging.
I had a jet jockey who had a 701 tell me this was the hardest plane to land he had ever flown. I haven't had that experience. Maybe it is because I don't have that much experience to compare it to. I'm having a blast with mine.
Paul Tipton
321PT
180 hours
n85ae
PostPosted: Thu May 08, 2008 7:01 am    Post subject: Re: Landing the 701 Reply with quote
My tailwheel instructor claimed the absolute hardest pilots he ever taught
to fly light planes were Jet Jockeys .... Smile
I've mostly flown tailwheel for the last eight years, seems like some tail
wheel instruction my help. I realize before anybody jumps on me, that
tri-gear 701's are totally different. However I became a much better
tri-gear pilot after I got my tailwheel endorsement.
I think a lot has to do with learning to land the airplane 3-pt, and also
how to do wheel landings helps put you much more in tune with landing
speed and aircraft attitude.
One thing that I have noticed flying with a some tri-gear drivers is
that some are not very adept at carrying the nose during landing and
tend to land flat. Which if you do in a taildragger will lead to an enormous bounce.
Not saying it's a cure, but it's good instruction that might help.
Ok, flame away Smile
regards,
Jeff
