Switch for Hobbs.
mp.gamble(at)tiscali.co.u
PostPosted: Mon May 05, 2008 8:20 am    Post subject: Switch for Hobbs. Reply with quote
What are chaps using to switch their hobbs timer on with engine start? Is there an alternative to the n/o oil pressure switch? - perhaps sensing alternator output.
Mike Gamble
topglock(at)cox.net
PostPosted: Mon May 05, 2008 9:58 am    Post subject: Switch for Hobbs. Reply with quote
Mike,
I used a standard marine ignition switch to supply current to the
starter, with rockers for the ignition circuit. The "run" side of the
ignition switch supplies power for the hobbs and the trim circuit breaker.
Jeff - Baby Blue
Mike Gamble
Checked by AVG.
nwcmc(at)tiscali.co.uk
PostPosted: Tue May 06, 2008 6:34 am    Post subject: Switch for Hobbs. Reply with quote
Attached is the circuit I used.
Nigel Charles
 Filesize:  63.67 KB
 Viewed:  285 Time(s)
gcsmith(at)flyer.co.uk
PostPosted: Wed May 07, 2008 7:04 am    Post subject: Switch for Hobbs. Reply with quote
I used a small vacuum switch from Radio Spares connected to the engine-driven vacuum pump
Graeme Smith
G-CCGW
2008/5/5 Mike Gamble <mp.gamble(at)tiscali.co.uk (mp.gamble(at)tiscali.co.uk)>:
[quote] What are chaps using to switch their hobbs timer on with engine start? Is there an alternative to the n/o oil pressure switch? - perhaps sensing alternator output.
Mike Gamble
dangerous content by Houxou, and is
believed to be clean. [b]
Troy Maynor
PostPosted: Thu May 08, 2008 6:13 pm    Post subject: Switch for Hobbs. Reply with quote
Mike,
Aeroelectric sells a double throw oil pressure switch you can connect up that when engine is not running turns on an oil light LED for a Master Switch left on warning, and flips the other way when engine is running to operate a hobbs. FWIW......Not flying yet so can't vouch, but that's my plan.
Troy Maynor
Visit - www.EuropaOwners.org
