ding(at)tbscc.com Guest
Posted: Sat May 03, 2008 4:34 pm Post subject: Trim Controls |
I'm currently wiring my panel (601 XL), and temporarily connected my elevator trim switch and indicator to the servo to check operation before making final connections. I tested with a 9 volt radio battery as suggested in the instructions. The results were different than expected. I wired the servo leads so that pushing the top of the rocker will raise the nose by lowering the trim tab. This results in the indicator needle dropping below center. The indicator is showing the position of the tab rather than the resultant position of the elevator. This seems backwards to me. What is correct?
Lynn Dingfelder
Corry, PA ding(at)tbscc.com (ding(at)tbscc.com) 95% plus paint
steerr(at)bellsouth.net Guest
Posted: Sat May 03, 2008 5:31 pm Post subject: Trim Controls |
I had the same thing when I tried it. I just turned the indicator
upside down.
| Quote: | I'm currently wiring my panel (601 XL), and temporarily
s.c.richards(at)homecall. Guest
Posted: Sun May 04, 2008 12:52 am Post subject: Trim Controls |
Turn indicator 180 degrees or swap over orange blue connections at indicator or servo
Clive
georgerace
Posted: Sun May 04, 2008 3:44 am Post subject: Trim Controls |
Would probably be easiest to simply swap the indicator leads to reverse the direction the meter moves. Not recommended that you mount the meter upside down.
George
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of dingfelder
Sent: Saturday, May 03, 2008 8:30 PM
Subject: Trim Controls
Lynn Dingfelder
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
Posted: Sun May 04, 2008 11:25 am Post subject: Trim Controls |
Thanks to all who responded concerning trim indicators. Great info, problem solved
Lynn Dingfelder Corry, PA
