[Probable Spam] 701 Nose gear stop (7F8-6)
larry(at)macsmachine.com
PostPosted: Wed Apr 30, 2008 9:53 am    Post subject: [Probable Spam] 701 Nose gear stop (7F8-6) Reply with quote
Hi Stanley,
I'd recommend you add bearing nylon to the top edge of the stops similar
to what's seen in this link.
Straight surfaces are better than curved as I found out after and
changed back to straight. Link below,
http://www.macsmachine.com/images/gear/full/stratstops.gif
Stanley Challgren wrote:
<challgren(at)mac.com>
Builders:
I followed the measurements exactly when fabricating the Nose Gear
Stop (7F8-6). The problem with that was that I was off about 1/8"
somewhere else when doing the Nose Gear Strut Assembly (7L1-1J). The
result is a gap of about 1/8" between the Nose Gear Stop and the steel
tube to which the steering rods attach. Rather than ordering new Nose
Gear Stops from Zenair I am considering adding some bearing material
as that contained in the Lower Bearing (7F7-4C).
The list has previously had pictures of such a fix and the material
was named but I cannot locate either in my files. I can find nothing
in Aircraft Spruce that resembles what I am looking for. Could
someone help me out with the name and where the item can be purchased?
Stan
N701VG (Reserved)
3300 & FWF arrives in May
PostPosted: Thu May 01, 2008 8:22 am    Post subject: [Probable Spam] 701 Nose gear stop (7F8-6) Reply with quote
Larry and Bob:
Thanks for your rapid response. Just ordered 5 feet from Mcmaster-Çarr.
Stan
On Apr 30, 2008, at 11:53 AM, LarryMcFarland wrote:
Hi Stanley,
similar to what's seen in this link.
