gfr56(at)comcast.net Guest
Posted: Tue Apr 29, 2008 11:55 am Post subject: z13/8 question |
Greetings
Refering to the Fig Z-13/8 and the wiring of the Endurance bus the
connection from the Main bus is not protected with a fuse or breaker
yet the feed from the battery bus is protected with a fuse at the bus
block and a fuse link between the e-bus alternate feed switch and the
endurance bus, what is the concept behind this?
Also on the same figure Z-13/8 the connection between the DC Power
Master Switch and the Main Power Distribution Bus has both a breaker
and a fuse link, what is concept behind this?
On the same diagram the wire gage for the connection between the Main
Power Distribution Bus and the Endurance Bus has an * denoting "6
inches or less" . In my installation the wire run will be longer than
six inches. Do I need to use a larger gage wire?
Thanks in advance Jerry
nuckolls.bob(at)cox.net Guest
Posted: Tue Apr 29, 2008 6:56 pm Post subject: z13/8 question |
At 09:54 AM 4/29/2008 -0400, you wrote:
Greetings
Note the (*) symbol on short feeders which if kept
down to 6" or so, are not generally considered worthy
of protection. If the main and e-bus fuse blocks are
co-located with the normal feedpath diode, then protection
can be dispensed with.
| Quote: | Also on the same figure Z-13/8 the connection between the DC Power
The wire from the bus to the alternator field breaker is an
EXTENSION of the bus . . . which is also a long wire and
generally worthy of some protection. However, if you use
crowbar ov protection, the fusing-constant for the upstream
protection needs to be much longer than the fusing constant
for the crow-bar breaker. Hence, the fusible link which will
carry enough current to crow-bar the breaker without
opening itself.
| Quote: | On the same diagram the wire gage for the connection between the Main
The "six-inch-rule" is a wiring practice adopted by the
certificated aircraft world for the purpose of deciding
whether or not fault protection is needed. It's up to
you if you want to adopt a "12-inch-rule" . . . or whatever.
It's not a wire size issue.
( -Thomas Paine 1776- )
Posted: Wed Apr 30, 2008 3:56 am Post subject: z13/8 question |
Many Thanks
Jerry
