Key Switch
edchristian(at)knology.ne
PostPosted: Fri Apr 25, 2008 6:57 am    Post subject: Key Switch Reply with quote
Does someone have a Z-11 diagram with a keyed ACS type switch (Off/L/R/
Start)? Redoing panel and using some old components - I know it is not
optimum.
Ed
nuckolls.bob(at)cox.net
PostPosted: Fri Apr 25, 2008 7:45 am    Post subject: Key Switch Reply with quote
At 10:53 AM 4/25/2008 -0400, you wrote:
<edchristian(at)knology.net>
optimum.
Figure Z-26 is the adjunct drawing to support the legacy
magneto/start switch. Keep in mind that all the Z-Figures
are intended to suggest architectures. The customization
of wire gauges, fuse/breaker sizes, bus structures,
alternator, starter, and ignition selections make for a
few million different combinations of electrical system
drawings . . . all of which conform to the spirit and
intent of Z-11.
rhdudley1(at)bellsouth.ne
PostPosted: Fri Apr 25, 2008 11:56 am    Post subject: Key Switch Reply with quote
Hi Ed,
The system rejected my attachment in CAD format.
So I am trying again with a DWG format.
Richard Dudley
RV-6A flying
MainDrawing.DWG
 Filename:  MainDrawing.DWG
 Filesize:  159.35 KB
 Downloaded:  276 Time(s)
