Proposed Sport Pilot and LSA rule changes
avidfox
PostPosted: Fri Apr 18, 2008 6:26 pm    Post subject: Proposed Sport Pilot and LSA rule changes Reply with quote
Proposed change #9.... is for Lynns next west coast trip. ; )
http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf
Me,... I'm just happy flying a Series 5 up to the Maximum Takeoff Weight of 1320 lbs. under sport pilot privileges.
Steve
84KF
KF5\912UL
 Filesize:  577.77 KB
 Viewed:  628 Time(s)
thesupe(at)hotmail.com
PostPosted: Fri Apr 18, 2008 8:14 pm    Post subject: Proposed Sport Pilot and LSA rule changes Reply with quote
Lots of discussions on the Fly-Ul site about the hour of under the hood time for sport pilots flying in planes with a VH over 87 Knots. Other than maybe some of the new $100,000 + sport planes, how many sport planes have the instruments you would need. Not many I would guess. ????? Jim Chuk Avids Kitfox 4 Mn
[quote] Subject: Proposed Sport Pilot and LSA rule changes
Date: Fri, 18 Apr 2008 19:26:29 -0700
--> Kitfox-List message posted by: "avidfox" <avidfox(at)gmail.com>
Steve
84KF
KF5912UL
http://forums.matronics.com/viewtopic.php?p=177791#177791
http://forums.matronics.com//files/006_205.jpg
Going green? See the top 12 foods to eat organic.
Michfox5
PostPosted: Fri Apr 18, 2008 8:31 pm    Post subject: Re: Proposed Sport Pilot and LSA rule changes Reply with quote
That would be proposed change #5.
5. Require 1 hour of flight training on the
control and maneuvering of an airplane
solely by reference to instruments for
student pilots seeking a sport pilot
certificate to operate an airplane with a
maximum airspeed in level flight with
maximum continuous power (VH) greater
than 87 knots calibrated airspeed (CAS)
and sport pilots operating airplanes with
a VH greater than 87 knots CAS
Notice it says "of AN airplane...." it dosen't specify that it must be LSA or sport pilot eligible.
A Cessna 150 would cover that issue.
Steve
84KF
Guy Buchanan
PostPosted: Fri Apr 18, 2008 8:43 pm    Post subject: Proposed Sport Pilot and LSA rule changes Reply with quote
Steve,
Thanks for finding these. I hope this list only applies to
pilots and instructors, and not to aircraft, otherwise it's a
disappointment. I really thought they'd clarify the weight issue. And
what about that altitude restriction! I guess Lynn will have to get
the portable O2 system!
Steve
84KF
KF5912UL
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Lynn Matteson
PostPosted: Sat Apr 19, 2008 9:06 am    Post subject: Proposed Sport Pilot and LSA rule changes Reply with quote
Well, by golly, they must've read my mind......"Sir, I'd like one
bottle of oxygen and a Sectional chart for Leadville, Colorado,
please....and take your time on the delivery, as the rule is not in
place yet." But I can hope. : )
Lynn Matteson
Grass Lake, Michigan
flying w/490+ hrs
Steve
84KF
KF5912UL
Lynn
Kitfox IV-Jabiru 2200
N369LM
vetdrem
PostPosted: Sat Apr 19, 2008 5:47 pm    Post subject: Re: Proposed Sport Pilot and LSA rule changes Reply with quote
The 10,000 ft limit is being addressed in the new revision that is being routed through the system. It will be 10,000 ft MSL or 2,000 ft AGL which ever is higher.
You can read about the proposed change at http://www.eaa.org/news/2008/2008-04-11_sport_pilot.asp
