jim.lanier(at)charter.net Guest
Posted: Sat Apr 19, 2008 9:18 pm Post subject: Nose Rib Template DWG 6-T-4 |
I have a question about the form block and raw aluminum shape/size of
the nose rib before bending.
The ribs 1-4 are shown in a pre-bend template drawing. I see no such
template for the nose rib.
The flange is 19mm on the sides and the spar end. It is the tip that is
unclear to me. Where does it show the flange dimension on the tip? What
is the shape/dimensions of the pre-bent aluminum to bolt to the form block?
Thanks is advance.
Jim
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Apr 20, 2008 8:16 am Post subject: Re: Nose Rib Template DWG 6-T-4 |
Jim,
I left about 5 mm at the nose for the rudder rib when I made the part. You're right though, I don't think the drawings show the dimension. I think if you make it look like the drawing you'll be in good shape.
Dan
plans building 601xl/Corvair
| Quote: | ="jim.lanier(at)charter.net"]I have a question about the form block and raw aluminum shape/size of
Thanks is advance.
Jim |
_________________ Scratch building XL with Corvair Engine |
