nuckolls.bob(at)cox.net Guest
Posted: Thu Apr 17, 2008 3:56 am Post subject: Rear Mounted Batteries - more questions |
At 02:54 PM 4/16/2008 -0700, you wrote:
Bob and list,
Using the previously attached document as reference...
Assumptions... rear mounted batteries. Main Bat Cntctr, Aux Bat cntctr
and Xfeed Cntctr all mounted in rear beside the batteries.
Hmmmm . . . normally we'd like to see the cross-feed contactor
mounted on the firewall. This provides nice fat-wire terminals
from both batteries to serve as distribution points for the
two batteries in addressing their respective tasks.
| Quote: | 2awg ground wire to fwd central gnd bus attached to the engine via stud
through firewall. XFEED cnctr closed for starting. 2AWG wire from the
same side of XFEED cntctr that the main bat cntctr is connected to
starter cntctr.
Okay . . .
| Quote: | Questions.... Can I then run appropriate sized wire (tbd) from the same
side of the starter cntctr as the 2awg wire is attached to the main pwr bus?
Yes. If your cross-feed contactor were up front
then the battery distribution tie point would be
on the cross-feed contactor. With the configuration
you've described, then the starter contactor becomes
the tie point.
| Quote: | If so, I also assume I would run appropriate sized wire ~8-10 awg (but not
the heavy 2awg) from aux bat side of the XFEED to the Aux bus and use same
wire to from the aux alt (prob 8 amp b&C alternator).
Oops . . . sounds like you're describing a Z-14
architecture using an SD-8 on the aux side. Not
recommended due to aux battery contactor loads being
such a significant portion of the SD-8's output.
Suggest a Z-13 architecture is more appropriate to
maximizing the capabilities of the SD-8.
| Quote: | Hope this makes sense. Really just trying to understand if I can only run
two fat wires from the batteries to the firewall if I want to ground at
the firewall or need to pull the extra "hot fat wire".
Let's talk about your architecture and choices
of hardware to fill the various slots. What
shortcomings do you perceive with a Z-13 architecture
that drives you toward dual batteries?
( -Thomas Paine 1776- )
n277dl
Posted: Thu Apr 17, 2008 2:07 pm Post subject: Re: Rear Mounted Batteries - more questions |
Bob,
Thanks for the response and heres some more details....
building a rv10, dual grt hx, 430w, sl30, tt - ap, lycoming io540 - one lightspeed ignition and one mag. Will have basic airspeed round gauges for backup... ie groudspeed, vsi, altimeter and an electric gyro attitude indicator. Have similar systems in RV7A except dynon not grt, no sl30 and all both mags.
Why two batteries...primarily rumblings on those with efis to the need to have the two batteries in starting to keep from resetting the boot-up operation of the efis's during engine startup (honestly, unverified by me). Adding an extra battery is an insignificant expense (relatively speaking). Having two batteries would make me more comfortable with dual electronic ignition in the future. I won't start that way as engine already ordered and configured but it's much easier to plumb for future than redo later.
In a previous post on the original thread you stated....
The crossfeed contactor, starter contactor and current limiter
block can be mounted within inches of each other and "wired" with
flat strap like the pictures found in this directory . . .
http://www.aeroelectric.com/Pictures/Wiring_Technique/
The short straps are much easier to fabricate and install than
very short hunks of fat wire with terminals.
So I'm a little confused. Maybe I took this one out of context and was specifically directed at firewall mounted batteries.
I've actually already ran the two 2awg fat wires to the front where I could mount the xfeed contactor but then found the above post and thought maybe it should only be one.
I'm on the road this week but will review the z13 tomorrow night. Maybe all I need and don't need the extra complexity.
Thanks again,
Doug
_________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
Posted: Fri Apr 18, 2008 7:17 am Post subject: Rear Mounted Batteries - more questions |
At 03:07 PM 4/17/2008 -0700, you wrote:
Bob,
than redo later.
> Quote:
> Bob . . .
Thanks again,
Doug
My apologies, I may have stuck my foot in it . . . my reason
is too many balls in the air at once . . . but no excuses.
Have I seen a power distribution diagram on your project? My
mental images of our discussion may well be tainted with
artifacts from discussions on other projects. My comment about
x-feed contactor on the firewall was based on some discussions
about rear mounted batteries when I produced a sketch that
looked like this:
http://www.aeroelectric.com/Pictures/Schematics/Z-14_w_Rear_Batteries_Metal_Aircraft.pdf
The thrust of this reasoning addressed the need to
have a convenient, robust place to tie off fatwires that
come forward from rear mounted batteries in a Z14-like
architecture. The most obvious solution was to place
the cross-feed contactor on the firewall irrespective
of where the batteries were located.
This provides the sought-after tie point for tying
the battery fat-wires into the rest of the system.
Let's back-track as needed to make sure my words are
supportive of your design goals. Do you have a z-figure
like drawing to share?
n277dl
Posted: Fri Apr 18, 2008 2:33 pm Post subject: Re: Rear Mounted Batteries - more questions |
Bob….
Started out with your published z14 drawing and began to understand the flow with them…
Then found the string referencing the z14_rough that uses non-local ground. Reviewed options and decided I wanted to use a central primary ground on the firewall / engine block.
That particular string also is where the discussion of keeping the XFEED CNTCTR and the Battery Cntctr’s located close and connected using copper/brass strapping which drove me to drawing up the very rough sketch with only one “+” fat wire running from the back to the front.
I think the biggest weakness of the “one wire” concept is that I would loose some of the benefit of the aux alternator as it would have to keep the aux battery cntctr closed. Think I read in either the “connection” or the list that it takes about 1amp to keep the contactor closed. Obviously, I’d lose 1/8th of the output of the SD8 in that scenario. Assuming that it’s okay to physically mount the xfeed contactor at the front instead of with the battery contactors, the only real advantage is one less “+” fat wire. Would still have to run something from the Aux alt and aux bus to the rear but it could be a smaller wire.
So all that said, maybe the simplest most efficient design would be moving the xfeed contactor to the front.
Also pondering the physical location of the battery bus (ie, the always hot bus). From what I can read it appears the recommendation is always having this bus physically located within 6-8 inches of the battery. Obviously this requires running wiring from the front to the back for all devices that you want powered via the battery bus. An option that I never see mentioned and therefore assume is a bad idea is to run one heavier wire from the rear mounted battery and physically locate the battery bus in the front. Again, I assume this is a bad idea but would you comment on why… I’m assuming that you wouldn’t want a non-fused wire ran that distance but thought I’d ask anyway.
These rear-mounted batteries are requiring some noodling as to where to physically mount things. Guess that's why they call it experimental
Thanks again for all your input. It sure helps to bounce things off someone that has done this more than once before.
Doug
rear bat_one fat wire fwd.pdf |
83.23 KB |
637 Time(s) |
z-14rough[1].pdf |
63.31 KB |
607 Time(s) |
Posted: Tue Apr 22, 2008 5:53 am Post subject: Rear Mounted Batteries - more questions |
At 03:33 PM 4/18/2008 -0700, you wrote:
Bob….
flow with them…
smaller wire.
Doug
I've been pondering this discussion for the last day or so and
I wasn't pleased with the lack of elegance. It seemed that your
design goals were not well served with the present suite of hardware
(too heavy).
An FMEA study of Z-13/8 yields and excellent reliability scenario
but it cannot address the fact that some modern EFIS products are
unable to deal with the real world of millisecond long, bus brownout
during starter-inrush loads. See:
http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1.jpg
Indeed, all single-battery systems are not designed to provide
a constant source of power that stays inside the operating
envelope of these computer based products.
One obvious solution is a second battery. The question is
how big? It only needs to supply power to a limited suite of
ship's hardware for a few tens of milliseconds while the starter
motor spins up at the onset of each cranking cycle. In terms
of ENERGY, the requirements are trivial. So the real sizing
considerations are for internal impedance of the battery. Ideally,
we'd like to put an array of AA NiMh cells in to support the e-bus
during brownout . . . but these cells have finicky charging
requirements. It's not that they wouldn't do the job . . . but
system design issues are more complex and parts count goes
up.
So what's a reasonable middle ground? Take a peek at:
Take a peek at this drawing I did last night:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8A(BrownOutBattery).pdf
Here I've suggested that you dump the #2 fat battery and
the fat contactors associated with #2 master and crossfeed.
Install a much smaller (7.2 AH, 5.5# 0.04 ohm) "brownout
battery" and a pair of cube power relays wired such that
the e-bus is supported ONLY by the brownout battery during
engine cranking and only while the main bus is loaded so
heavily that it cannot keep the EFIS from resetting.
This same technique could be added to any single battery
system (or even Z-14 where you wanted to use both batteries
for cranking). This modification to Z-13 does not burden the
SD-8 with supporting fat contactors that are never expected
to carry cranking currents . . . hence may be ably replaced
with smaller, plastic relays.
Posted: Tue Apr 22, 2008 7:33 pm Post subject: Rear Mounted Batteries - more questions |
At 10:42 AM 4/22/2008 -0700, you wrote:
| Quote: | Bob, Very interesting discussion....
We are (were) planning on using Z19RB architecture. Granted, that
requires 2 full size batteries (17- 20 AH) which we feel would provide
sufficient backup power in the event of alternator failure, redundant
power sources for the dual fuel pump and ignition required for the 20b
Mazda rotory engine and avoids the added expense and complication of the
extra alternator. To insure good batteries one would be replaced each year.
Our thought was the two batteries would provide adequate power even during
starts to prevent brownouts and a minimum of one and a half hours battery
power (with load shedding of course) in the event of an alternator failure.
That's consistent with the processes by which Z-19 was crafted.
Dual alternators is simply not a practical option for many
of the automotive conversions.
| Quote: | We have not tested this battery endurance yet as the panel is not finished.
You should be able to predict e-bus performance. The
Discharge curves for various battery products are generally
available from the manufacturer. Just keep in mind that
the useful capacity is not consistent with variable loads.
The higher the load, the more energy is lost internal to
the battery. In this family of curves . . .
http://www.aeroelectric.com/Pictures/Curves/17AH_12V_Capacity_vs_Load.gif
we see that a new 17 a.h. battery is good for
just over 2 hours with a 4 amp load. So about 1.5
hours when time to toss the battery. On the other
hand, a 10A load is good for about 60 minutes. If
one hour is the new-battery design goal, then end
of service life will be at about 45 minutes.
| Quote: | The brownout relay got me thinking about Z13/8 again....
Any thoughts????
It's up to you to decide what goodies are operated
during the alternator out operations and then decide
how much payload you're willing to trade for battery-
only endurance with those loads.
In VMC, your other-than-engine loads can probably
be VERY low thus offering more hours of electrical
support than you have fuel support. A set of pre-flight
tested hand-helds can certainly be part of your plan-B
equation.
Being limited to two batteries, one alternator and
a couple of hand-helds doesn't need to present a
worrisome situation.
