nuckolls.bob(at)cox.net Guest
Posted: Mon Apr 14, 2008 7:11 pm Post subject: 2 electrical questions - diode and intermittent failure |
At 04:20 PM 4/14/2008 -0600, you wrote:
The diode for the battery master, what are the specifications?
Twice now while flying my aircraft (over 100 hours with no problems), my
main power has flickered. Off and right back on. I just checked all the
wiring for the master, and the only thing I'm missing is the diode. Ground
was my obvious place to look, all OK, excellent ground for the master
switch.
My next choice is to change out the master solenoid. Any other ideas?
Rocket - dual alternator with single battery. Standard Z-13 wiring.
Thanks in advance,
Jeff
An intermittent battery master would not cause the
system to go down completely. In fact, it's possible
on some airplanes that an alternator will run reasonably
well without a battery . . . complete loss of the contactor
may not be immediately noticed.
If you're looking for loose wires, everything between
the bus and BOTH power sources (alternator and battery)
should be examined. Unless you soldered your terminals
on a good tug on the fat-wire terminals is in order.
I've seen wires installed with inadequate crimp tools
pull out of their respective terminals without a whole
lot of effort.
( -Thomas Paine 1776- )
f1rocket(at)telus.net Guest
Posted: Tue Apr 15, 2008 5:43 am Post subject: 2 electrical questions - diode and intermittent failure |
Hi Bob,
Thanks for the usual quick reply.
Just for my brain... If the alternator had a loose wire, wouldn't the
battery still supply the required power? I didn't think I would see the
power drop out if I lost the alternator (I was hoping I would get the low
voltage alarm so I could start the back up alternator).
Jeff
