2200 engine running question
ElleryWeld(at)aol.com
PostPosted: Mon Apr 07, 2008 5:25 pm    Post subject: 2200 engine running question Reply with quote
I just started test flying an X-Air with a 2200 engine the engine starts great idles super but when I really give it a lot of throttle and put the plane in a steep climb it hitches on regular intervals for a while then it will run fine until I start climbing steep or make a steep turn what should I look for to cure this problem ?
as long as I don't jab the throttle or make aggressive maneuvers it runs great
Ellery in Maine
Planning your summer road trip? Check out AOL Travel Guides.
notsew_evets(at)frontiern
PostPosted: Mon Apr 07, 2008 5:47 pm    Post subject: 2200 engine running question Reply with quote
Does it "hitch" with a constant throttle setting ?
ie, without moving the throttle and just pulling back the stick does it hitch?
SW
PostPosted: Mon Apr 07, 2008 5:58 pm    Post subject: 2200 engine running question Reply with quote
Yes it does
Ellery in Maine
In a message dated 4/7/2008 9:48:08 P.M. Eastern Daylight Time, notsew_evets(at)frontiernet.net writes:
[quote] Does it "hitch" with a constant throttle setting ?
SW
PostPosted: Mon Apr 07, 2008 6:15 pm    Post subject: 2200 engine running question Reply with quote
Might check that the butterfly valve isnt going open "too far". Thats what it was on my 2200A.
PostPosted: Mon Apr 07, 2008 6:32 pm    Post subject: 2200 engine running question Reply with quote
I will check it in the morning Thanks for the info I hope it will give me the fix I need
Thanks a bunch
Ellery in Maine
In a message dated 4/7/2008 10:15:59 P.M. Eastern Daylight Time, notsew_evets(at)frontiernet.net writes:
[quote] Might check that the butterfly valve isnt going open "too far". Thats what it was on my 2200A.
PostPosted: Mon Apr 07, 2008 6:51 pm    Post subject: 2200 engine running question Reply with quote
Its always wise to just call Jabiru Pacific in Fresno California.
Jim is extreamly helpful. Tell him Steve Weston, 2200A AND 3300A sent you....
SW
plus2s
PostPosted: Mon Apr 07, 2008 6:57 pm    Post subject: 2200 engine running question Reply with quote
Could be worth checking the float level also, could be on the low side  - Keith
PostPosted: Mon Apr 07, 2008 6:58 pm    Post subject: 2200 engine running question Reply with quote
Thanks again if that doesn't fix my problem I will call him
Ellery in Maine
In a message dated 4/7/2008 10:52:20 P.M. Eastern Daylight Time, notsew_evets(at)frontiernet.net writes:
[quote] Its always wise to just call Jabiru Pacific in Fresno California.
SW
PostPosted: Mon Apr 07, 2008 7:08 pm    Post subject: 2200 engine running question Reply with quote
I have already checked that and its not the problem I have ,but Thanks for your reply any info is helpful and worth looking at to get a problem straightened out
Ellery in Maine
In a message dated 4/7/2008 10:57:52 P.M. Eastern Daylight Time, kpickford(at)xtra.co.nz writes:
-----Original Message-----
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of ElleryWeld(at)aol.com
Sent: Tuesday, April 08, 2008 2:27 PM
Subject: Re: 2200 engine running question
[b] I will check it in the morning Thanks for the info I hope it will give me the fix I need [/b]
[b]Thanks a bunch [/b]
[b]Ellery in Maine[/b]
[b]do not archive[/b]
----- Original Message -----
From: ElleryWeld(at)aol.com (ElleryWeld(at)aol.com)
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Sent: Monday, April 07, 2008 6:53 PM
[b]Yes it does [/b]
[b]Ellery in Maine [/b]
[b]       [/b]
In a message dated 4/7/2008 9:48:08 P.M. Eastern Daylight Time, notsew_evets(at)frontiernet.net (notsew_evets(at)frontiernet.net) writes:
SW
Sent: Monday, April 07, 2008 6:20 PM
[b]I just started test flying an X-Air with a 2200 engine the engine starts great idles super but when I really give it a lot of throttle and put the plane in a steep climb it hitches on regular intervals for a while then it will run fine until I start climbing steep or make a steep turn what should I look for to cure this problem ? [/b]
[b]as long as I don't jab the throttle [/b] [b]or make aggressive maneuvers it runs great [/b]
href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
st href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List.matronics.com/">http://forums.matronics.com://www.matronics.com/contribution">http://www.matronics.com/contribution
6
5
6
7
8
9
5
6
7
8
9
plus2s
PostPosted: Mon Apr 07, 2008 7:31 pm    Post subject: 2200 engine running question Reply with quote
Yep – sounds like a fuel problem , but its worth checking the coil clearance as well.- keith
Lynn Matteson
PostPosted: Tue Apr 08, 2008 4:40 am    Post subject: 2200 engine running question Reply with quote
When it is hitching, does applying the "choke" help or hinder it? I
finally determined that my recent carb problems were caused by low
float level, and possibly using the very light-sprung float needle.
Mine hitched just after climbout began, and I got it back to the
field, hitching all the way.
Lynn Matteson
Grass Lake, Michigan
flying w/487+ hrs/down for annual
On Apr 7, 2008, at 9:53 PM, ElleryWeld(at)aol.com wrote:
[quote] Yes it does
Ellery in Maine
does it hitch?
SW
Lynn
Kitfox IV-Jabiru 2200
N369LM
Lynn Matteson
PostPosted: Tue Apr 08, 2008 4:45 am    Post subject: 2200 engine running question Reply with quote
Just curious...is this a pusher configuration, or tractor?
It sounds like a fuel level problem to me. Last week I talked to Bing
and the very knowledgeable lady there said that to check fuel level,
lower the bowl and there should be 1/2" of air space from the fuel to
the top of the bowl.
Lynn Matteson
problem ?
it runs great
Ellery in Maine
www.matronics.com/Navigator?JabiruEngine-List _-
www.matronics.com/contribution _-
Lynn
N369LM
PostPosted: Tue Apr 08, 2008 4:51 pm    Post subject: 2200 engine running question Reply with quote
Well I checked it this morning and that is what I came up with the fuel in the carb bowl was 1/2" inch below the top I adjusted the Float reinstalled the float Bowl and fired up the engine for a minute removed the float bowl and now it is 1/8" from the top and that cured my hitching problem That Problem solved now, Thanks for the info Guys.
I got the test flight on this one finished
NOW I WILL STAND BACK AND THROW ROCKS AT 912 rotax engines
now it was a bit warmer today and the oil temp was able to get to hi oil temp range What are you guys running for oil coolers on your engines this guy I built this plane for didn't want one but now I showed him that it will need one during summer months and do you use oil thermostats in the system?
Ellery in Maine
In a message dated 4/8/2008 8:41:07 A.M. Eastern Daylight Time, lynnmatt(at)jps.net writes:
--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Yes it does
Ellery in Maine
does it hitch?
SW
problem ?
it runs great
Ellery in Maine
www.matronics.com/Navigator?JabiruEngine-List href="http://
forums.matronics.com">http://forums.matronics.com href="http://
www.matronics.com/contribution">http://www.matronics.com/c st
List .matronics.com/">http://forums.matronics.com ://
========================= Use lities y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ;   =========================
Lynn Matteson
PostPosted: Tue Apr 08, 2008 7:44 pm    Post subject: 2200 engine running question Reply with quote
You might have a leaking float needle valve. Your fuel shutoff might
not be holding securely, allowing excess fuel to leak into the bowl
just as you lower the bowl to check the amount in there. You would
have to be almost overflowing the bowl to be able to lower the bowl
from the carb, and have 1/8" of fuel below the top...the floats would
account for more volume than this. Something doesn't sound right here.
Lynn Matteson
On Apr 8, 2008, at 8:47 PM, ElleryWeld(at)aol.com wrote:
[quote] Well I checked it this morning and that is what I came up with the
for the info Guys.
Ellery in Maine
Lynn Matteson
> Yes it does
> Ellery in Maine
> do not archive
> does it hitch?
> SW
Lynn
N369LM
PostPosted: Wed Apr 09, 2008 3:15 am    Post subject: 2200 engine running question Reply with quote
it did spill a bit when I removed the Bowl ,I will drop the bowl and check it again once in a while but it's not overflowing and running fuel all over everything
Ellery in Maine
In a message dated 4/8/2008 11:45:39 P.M. Eastern Daylight Time, lynnmatt(at)jps.net writes:
[quote]--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
for the info Guys.
Ellery in Maine
Lynn Matteson
> Yes it does
> Ellery in Maine
> do not archive
> does it hitch?
> SW
