Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Mon Mar 31, 2008 2:46 am Post subject: To Hinge or not to Hinge |
In the 601 XL kit I have the option to use the original aileron hinge or the newer piano hinge.
Can any one tell the different qualities of both systems. I have conflicting reports on both. One says the piano hinge is lighter to fly with.
Thank you
Ianrat
psm(at)ATT.NET Guest
Posted: Mon Mar 31, 2008 5:16 am Post subject: To Hinge or not to Hinge |
Hi Lanrat,
I think the hingeless ailerons are a better choice, but either choice
will produce a nice airplane. The differences are relatively minor.
The hingeless ailerons are stiff. This is not a problem since it is
the force transferred from your pressure on the stick to the roll
performance of the airplane that counts rather than the movement of
the stick in the roll control direction. Under most circumstances
the stick doesn't actually move a noticeable amount.
The hinged ailerons probably provide more stick movement under some
conditions, but actually provide less performance. This is because
the hingeless ailerons are perfectly sealed while some air flow leaks
around and through the hinges. This seal becomes important when
considering the low speed roll performance of the plane.
Still, my main point is the decision is not a major one.
Paul
XL fuselage
At 03:46 AM 3/31/2008, you wrote:
| Quote: | In the 601 XL kit I have the option to use the original aileron
Thank you
Ianrat
daveaustin2(at)primus.ca Guest
Posted: Mon Mar 31, 2008 5:36 am Post subject: To Hinge or not to Hinge |
I had HD wings for 5 years without the hinges - then 10 years with HDS wings
with hinges. Aileron control is somewhat lighter for small inputs and
significantly lighter for large inputs.
I found the hinges to be less tiring on long trips and gave the a/c
"better" balance between aileron and elevator control. I say "better" as
elevator control is very light compared with ailerons with either no hinge
or hinge.
Dave Austin 601HDS - 912, Spitfire Mk VIII
bill_dom(at)yahoo.com Guest
Posted: Mon Mar 31, 2008 6:22 am Post subject: To Hinge or not to Hinge |
The hingeless are better aerodinamically speaking, slightly lighter in weight and simpler to assemble. I chose the piano hinge option mostly because I can remove the aileron without removing any rivets - removing the ailerons and flaps simplify a lot of issues with trailering and storing the plane in its trailer - but this is something most people won't need to do.
William Dominguez
Zodiac 601XL plans
Miami Florida
http://www.geocities.com/bill_dom
Ianrat <ianrat(at)powerup.com.au> wrote:[quote] --> Zenith-List message posted by: "Ianrat"
Thank [quote][b]
pchapman(at)ionsys.com Guest
Posted: Mon Mar 31, 2008 7:49 am Post subject: To Hinge or not to Hinge |
Like Dave Austin, I also found the hinged ailerons better in flight.
For very small roll control adjustments I didn't mind the hingeless.
But when on final approach, at lower speed, making bigger corrections
for crosswinds and gusts, there I really noticed the awkwardness of
having very light pitch control, yet heavier roll pressures. The roll
pressures were not "too heavy" on their own, but the control harmony
certainly could have been better. (This was on a 601 HD.)
Peter Chapman
Toronto, ON
amyvega2005(at)earthlink. Guest
Posted: Mon Mar 31, 2008 9:48 am Post subject: To Hinge or not to Hinge |
the skin hinge as I call it is a little stiffer, but mostly you have to hold the stick in the direction you want to turn or it flexes back to neutral. The hinge is like any other plane, turn and the plane will continue to turn. The skin hingless system has a neutral deflection memory. Thats it.
Juan
Posted: Mon Mar 31, 2008 10:13 am Post subject: To Hinge or not to Hinge |
Not true, if done right it is not any more aerodynamic than hingeless.
Juan
Gig Giacona
Posted: Mon Mar 31, 2008 10:35 am Post subject: Re: To Hinge or not to Hinge |
The folks that sell gap seals will be surprised to hear that. The stopping of airflow through the hinge is what those things do.
| amyvega2005(at)earthlink. wrote: | Not true, if done right it is not any more aerodynamic than hingeless.
Juan
3.36 KB |
4484 Time(s) |
601XL Under Construction
