rivet-smasher(at)comcast. Guest
Posted: Sat Mar 29, 2008 5:35 am Post subject: headset wiring |
I have an older Telex headset that is mono and only has two wires for the speakers and two wires for the microphone. I have the speakers wired up and they work fine.
The microphone has two wires but the plug has three solder connections on it, Tip, Ring, Sleeve.... Which is the proper location for these two wires for it to work..
Robin
Posted: Sat Mar 29, 2008 6:13 am Post subject: headset wiring |
Robin wrote:
| Quote: | I have an older Telex headset that is mono and only has two wires for
Robin
The tip is intended to carry the Push-To-Talk line.
The ring is mic audio 'hi' or 'positive' or '+'.
The sleeve is 'lo' or 'return' or 'ground', depending on who writes the
docs.
If you have an inline portable PTT switch, when you push the button, the
tip is connected to the sleeve (pulling the PTT sense line in the radio
to near zero volts), telling the radio to go into transmit mode.
Charlie
Vanremog(at)aol.com Guest
Posted: Sat Mar 29, 2008 8:41 am Post subject: headset wiring |
In a message dated 3/29/2008 6:36:20 A.M. Pacific Daylight Time, rivet-smasher(at)comcast.net writes:
| Quote: | | The microphone has two wires but the plug has three solder connections on it, Tip, Ring, Sleeve.... Which is the proper location for these two wires for it to work. |
The proper plug is called a TRS (tip, ring, sleeve) and the mic connections on a normally wired aircraft are MIC=Ring and MIC_RTN=Sleeve. If you use an external (inline) Mic key switch then MIC_KEY=TIP.
N1GV (RV-6A, Flying 887hrs, O-360-A1A, C/S, Silicon Valley)
Create a Home Theater Like the Pros. Watch the video on AOL Home.
