ez(at)embarqmail.com Guest
Posted: Sat Mar 29, 2008 5:15 am Post subject: Prop flex |
Here is a good in flight picture of my 72 inch IVO prop flex profile.
On Mar 29, 2008, at 8:30 AM, N27SB(at)aol.com (N27SB(at)aol.com) wrote: | Quote: |
In a message dated 3/28/2008 10:51:25 P.M. Eastern Daylight Time, orcabonita(at)hotmail.com (orcabonita(at)hotmail.com) writes:
Prop tips in general should not flex much, the centrifugal force of rotation keeps most props straighter when running than when stopped. What kind of prop is that ???
Mike
| Mike, I am not sure where you got your info on prop flex. The tips of an Ivo Prop flex forward in excess of an inch. Other props flex less. On a Kolb with an upswept boom this tends to increase clearance, However, it can dramatically decrease clearance to the back of the wing.
Steve B
Firefly 007/Floats
[img]cid:B3AA3973-528A-48B1-9F4E-4D40A5117893(at)gateway.2wire.net[/img]
76.64 KB |
311 Time(s) |
