DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu Mar 27, 2008 5:22 pm Post subject: Alternator Breaker Pop |
I am performing my first engine runs with a Jabiru 3300 powered Zenith 601XL. This is a PM alternator and my wiring is based on the Z16 architecture using the S704-1 alternator control and crowbar OV protection. So far everything is working just fine with one exception. Of the 10 or so engine starts I have made, twice I found the 5A alternator breaker popped. This is the breaker between the main bus and the master switch. On both occasions, the engine was at idle and I shut it down then re-started it after a few moments. It was after the start that I noticed the popped breaker.
I don't know if the breaker popped on shutdown or during the re-start. In either case I was able to reset the breaker and all appeared to be OK.
Anybody have any ideas on what is going on here? All the volt and amp numbers I have seen are "in the green." Do shutdown or start-ups cause nuisance pops?
DaveG
_________________ David Gallagher
Cincinnati, OH area |
Joined: 28 Mar 2008 Posts: 1973 Location: Riley TWP Michigan
Posted: Fri Mar 28, 2008 8:31 am Post subject: Re: Alternator Breaker Pop |
A wire could be intermittently shorting to ground or there could be an over-voltage condition. Shut off all expensive electronics, then try disconnecting the wire at the master switch that goes to the over-voltage module and see if the problem goes away. If it does, then there could be an over-voltage condition. The battery should help prevent voltage spikes. Does the battery contactor remain energized until the engine stops turning?
_________________ Joe Gores |
nuckolls.bob(at)cox.net Guest
Posted: Fri Mar 28, 2008 8:15 pm Post subject: Alternator Breaker Pop |
At 06:22 PM 3/27/2008 -0700, you wrote:
<david.m.gallagher(at)ge.com>
nuisance pops?
The crowbar ov protection module has been known to
trip on system noises. I've helped a number of builders
track down a noise source that was irritating the
OVM-14. How long have you had your OV module? There
were some changes about 4-5 years ago that made them
more resistant to all but the worst noises.
This is a pretty rare condition. It could also
be that your particular OVM has a problem. You
can send it to me for a checkout and update too
if you've had it a very long time.
I've not built and sold these for about 6 years
but I can help you tame the little beast.
DaveG601XL
Posted: Sat Mar 29, 2008 3:48 am Post subject: Re: Alternator Breaker Pop |
Bob,
I have purchased all of my electrical parts since September so barring any of it sitting on B&C's shelves for a long time, everything should be fairly new. I have not had the chance to go over the system wire-by-wire yet. I will report back after I have had the chance.
