mike109g6(at)insideconnec Guest
Posted: Mon Mar 24, 2008 9:56 pm Post subject: S700-2-1 wiring |
Bob or any other electrical wizard...
Used a S700-2-1 DPDT on-off-on switch to wire my avionics master switch to include panel lights for 'main bus' and 'bat bus'.
wired it like this:
#3 bat bus & light post #4 light post
#2 avionics bus #5 grnd
#1 main bus & light post #6 light post
When I toggle 'bat bus' instruments come on - no light
When I toggle 'off' - everything off
When I toggle 'main bus' - everything off
When I turn master switch on(battery Cessna Split Switch)
'main bus' instruments on - no light
What am I doing wrong to get no lights? New switch from B&C. Lights from B&C 12V - Lights work-checked separately direct to battery.
Thanks in advance.
Mike H 9A/8A
nuckolls.bob(at)cox.net Guest
Posted: Wed Mar 26, 2008 3:52 am Post subject: S700-2-1 wiring |
At 01:51 AM 3/25/2008 -0400, you wrote:
| Quote: | Bob or any other electrical wizard...
wired it like this:
'off' -
everything off
Thanks in advance.
Mike H 9A/8A
Mike, can you do a schematic of how your system is wired
and post a scan to the List? I'm not sure my mental image
based on your words is an accurate depiction of the electron
map.
( -Thomas Paine 1776- )
Posted: Wed Mar 26, 2008 8:52 pm Post subject: S700-2-1 wiring |
Bob,
I figured out what was wrong. I didn't realize that the indicator lights
were LEDS and must be wired differently from bulbs. White dot on side of
light housing apparently meant 12v source. When I wired it that way(had it
reversed) the lights came on. HooRahh!.
Thanks for responding, wiring is completed-at last.
Mike H 9A/8A
