lwinger
Posted: Sun Mar 23, 2008 6:36 pm Post subject: Firewall spring back |
Fellow scratch builders,
I'm making the form blocks for my 601XL firewall. Any words of advice on how to taper the top (14 degrees open), sides (3 degrees open) and bottom (10 degree closed)?
Also, any special tips of forming the .018" galvanized steel?
Thanks.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
lwinger
Posted: Sun Mar 23, 2008 8:52 pm Post subject: Firewall spring back |
A quick follow up to my questions.
I do have quite a bit of experience in making form blocks for my rudder, horizontal stab, flaps, ailerons and wing ribs. I'm really asking about the uniqueness of this part's material (galvanized steel) and the open flanges (3 and 14 degrees).
Thanks again.
On Sun, Mar 23, 2008 at 7:36 PM, lwinger <larrywinger(at)gmail.com (larrywinger(at)gmail.com)> wrote:
[quote]--> Zenith-List message posted by: "lwinger" <larrywinger(at)gmail.com (larrywinger(at)gmail.com)>
Thanks.
Larry Winger
Tustin, CA
601XL/Corvair from scratch
Control surfaces and wings complete.
Bottom rear fuselage done
http://forums.matronics.com/viewtopic.php?p=172100#172100
Tustin, CA
afjones(at)BRAZORIAINET.C Guest
Posted: Mon Mar 24, 2008 5:43 am Post subject: Firewall spring back |
Hi Larry ,I built my firewall strictly to the plans and it worked perfectly .It did not require any additional twicking. I belive it is one of the better parts of my plane. As to how I got the angles correct I don't remember ,must not be a big thing . Wade Jones
cookwithgas
lwinger
Posted: Mon Mar 24, 2008 7:51 pm Post subject: Firewall spring back |
Thanks, guys. I'm going with the KISS method that you've outlined. Making flat flanges that are later tweaked makes life a lot easier for me. I'm off to bend some metal.
Larry Winger
On Mon, Mar 24, 2008 at 11:26 AM, cookwithgas <cookwithgas(at)hotmail.com (cookwithgas(at)hotmail.com)> wrote:
[quote]--> Zenith-List message posted by: "cookwithgas" <cookwithgas(at)hotmail.com (cookwithgas(at)hotmail.com)>
Hi Larry:
http://www.cooknwithgas.com/7_17_04_Firewall.JPG
As you can see from the above picture it does not take superior intelligence to build the firewall!
Just do it like all the other formed parts and it will be fine. It stays bent better since it is steel.
Here are some more photos from the process:
http://www.cooknwithgas.com/7_9_04_Firewall.JPG
http://www.cooknwithgas.com/7_9_04_FirewallCutting.JPG
http://www.cooknwithgas.com/7_17_04_FirewallParts.JPG
Keep Snipping and Hammering,
Scott Laughlin
Omaha, NE
601XL/Corvair
Finished & Flying
Tustin, CA
