7suds(at)Chartermi.net Guest
Posted: Mon Mar 24, 2008 4:47 pm Post subject: Inspecting Spars & Struts |
If you suspect there may be a need consider installing a couple inspection
ports between the strut attach points, it will give you a way to inspect mid
wing.
Lloyd C
IM MI.
Mod 5 912
akflyer
Posted: Mon Mar 24, 2008 6:23 pm Post subject: Re: Inspecting Spars & Struts |
when I re-built my wings, I put inspection rings at each place I may need to get in and look at. This included the ends of the drag tubes, over the pitot tube pick up and over each strut attach fitting. I dont plan on cutting them out unless I need to look but they are there if I need them.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
