cjpilot710(at)aol.com Guest
brian-1927(at)lloyd.com Guest
Posted: Sat Mar 22, 2008 7:19 pm Post subject: I Did! |
On Mar 22, 2008, at 6:13 PM, cjpilot710(at)aol.com wrote:
| Quote: | To make a bubble:
1. Set "Increase Bubble" knob in minimum position.
2. Tilt sextant to the left.
3. Slowly rotate the knob.
4. A bubble will be formed at the notch, visible on the right hand
side of the field of view.
5. Rotate knob slowly back and forth until proper size bubble is
obtained.
6. Move sextant to vertical position, i.e. when the bobble is in the
center of the field of view.
7. Slowly rotate knob to maximum increase position.
The above copied from the Kollsman S332C-300-961 manual And I bet
you thought I was a gen-ass.
No, but I thought you might have the info -- and you did. Thank you!
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
