Zodiac XL Cruise Speed with 80HP
jim.lanier(at)charter.net
PostPosted: Sat Mar 22, 2008 6:17 am    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
Can anyone tell me the difference in XL cruise speed between the 80hp
and the 100hp Rotax. The website does not show performance with that
engine. Also, how about with a 75hp VW conversion?
Jim
MHerder
PostPosted: Mon Mar 24, 2008 9:07 am    Post subject: Re: Zodiac XL Cruise Speed with 80HP Reply with quote
I have wondered about this from time to time, has anyone tried powering an XL with a Jab 2200?
I know the manual calls for 80-120 hp. My thoughts are that climb would be affected much more than cruise. I personally like the idea of having the extra power to get you out of trouble, but would imagine that even with an 80hp it would still probably out perform a Cherokee 140.
Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying
Matt Ronics
PostPosted: Mon Mar 24, 2008 3:03 pm    Post subject: Re: Zodiac XL Cruise Speed with 80HP Reply with quote
Already having on-hand a C-85, I called Zenith about using it in the XL. In summary, I was advised that I probably wouldn't be pleased with the performance. At the same time, I was told that this would be an excellent engine in a 601HD/S.
Of note you are asking for "cruise speed" with the 80hp engine. Note that, generally speaking, it is climb performance, and not cruise, that is effected more by changing cubes. For example, using Van's numbers for the RV-4, increasing the HP 17% will give you a 6% improvement in cruise and a 25% improvement in climb.
Having thought this through in the past, I recall coming to the conclusion that the XL with 85hp would perform like a C-150. I spoke with one 601HD (standard fat wing) owner with a C-85...his numbers were very close to or less than those of a C-150.
John75142
PostPosted: Mon Mar 24, 2008 3:43 pm    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
Would you be interested in selling the C-85?
John (Scratch building 701)
Kaufman, Tx
John Short
planecrazydld(at)yahoo.co
PostPosted: Thu Mar 27, 2008 4:51 am    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
you will lose one or the other more than one or the other! The way you select the prop is everything. More diameter and flatter pitch will always yield better climb than smaller diameter and higher pitch - they produce optimized cruise.
There is no reason that everyone in todays Experimental movement forgets that virtually all entry level airplanes used to be frugal gas sippers with extremely poor climb performance. If you chjoose to optimize the prop for climb and are willing to settle for a cruise of 100-110 you can still get great climb with the XL on well less than 100 hp.
ics <e_jocular(at)yahoo.com> wrote:
[quote]--> Zenith-List message posted by: "Matt Ronics"
Already having on-hand a C-85, I called Zenith about using it in the XL. In summary, I was advised that I probably [quote][b]
larry(at)macsmachine.com
PostPosted: Thu Mar 27, 2008 6:12 am    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
Matt,
The analogy to the C150 is pretty close, but I'd think improved by the
601s weight advantage and wing. The HD would be less because of the
thickness of the wing.
On the other hand, a HDS would not be a performer because the 23 foot
wingspan needs a 100 hp engine to climb and cruise decently. With my
Stratus Subaru, the
economy cruise is excellent and climb is very good, but the climb is
nowhere close to an HD with the same engine.
Mainwheels
PostPosted: Thu Mar 27, 2008 8:23 am    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
Hi;
The CH-601HDS easily outperforms the C150 with an 80 hp 912. Of course,
even more so with the 100hp.
Mike
CH-601 HDS
1200+hours
LarryMcFarland wrote:
Matt,
Stratus Subaru, the
PostPosted: Tue Apr 01, 2008 5:12 am    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
I chose to work the numbers to get an approximation of the cruise performance of 100hp vs 80hp engines.
The Cd x A product was chosen to equal the Zenith website results for 100hp. If 100hp yields 134mph, then
80hp would achieve 124.35mph. This will at least get you in the ballpark. There are so many variables, that it is difficult to
get exact figures.
The Cd x A product would be greater at reduced velocity due to increased angle of attack. The wing lift is greater at reduced velocity
due to the lift vector angle deviating more aft of the normal force. The thrust vector angle also deviates slightly.
The weight of the 80hp engine would be (you would think) lower though.
[img]cid:part1.06000300.04080300(at)charter.net[/img]
[img]cid:part2.01090109.07030905(at)charter.net[/img]
Jim
 Filesize:  9.2 KB
 Viewed:  782 Time(s)
 Filesize:  9.36 KB
 Viewed:  762 Time(s)
ashontz
PostPosted: Fri Apr 04, 2008 9:41 am    Post subject: Re: Zodiac XL Cruise Speed with 80HP Reply with quote
That's an interesting equation. Do you have more info on it. Reminds me of the rule of thumb, 25% more power to go 10% faster.
get exact figures.
Jim
PostPosted: Fri Apr 04, 2008 12:10 pm    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
Hi Andy,
Sure. Here it is...
Fd = (1/2)(dens)(v^2)(A)(Cd)
Pwr = (Fd)(v) or Pwr = (1/2)(dens)(v^3)(A)(Cd)
dens = 1.293 kg/m^3 at 0°C and 1 atmosphere
Fd = drag force in Newtons (kg m/sec^2) (Isaac and I go way back..we used to go to different schools together Smile )
v = velocity m/s
A = cross sectional area in m^2
Cd = drag coefficient
Pwr = power in watts (kg m^2/sec^3)
[img]cid:part1.02060307.01030401(at)charter.net[/img]
[img]cid:part2.07080208.03080203(at)charter.net[/img]
I don't know what Cd is (or A for that matter), but they are a product in the formula. So although they may both be wrong, their product is OK.
You could say that this is a normalized solution.
Note: You can convert the drag and power formulas to Engish units if you want, but I prefer to do everything in metric and convert afterwards. Note in the spreadsheet examples above
that I converted Watts to HP after the equation was resolved.
Jim
ashontz wrote:
--> Zenith-List message posted by: "ashontz" <ashontz(at)nbme.org> (ashontz(at)nbme.org)
get exact figures.
[img][url=cid:part1.06000300.04080300(at)charter.net]cid:part1.06000300.04080300(at)charter.net[/url][/img]
[img][url=cid:part2.01090109.07030905(at)charter.net]cid:part2.01090109.07030905(at)charter.net[/url][/img]
Jim
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
http://forums.matronics.com/viewtopic.php?p=174819#174819
frankroskind(at)HOTMAIL.C
PostPosted: Fri Apr 04, 2008 12:48 pm    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
I don't know what is wrong with the calculatinos, but something would have to be. If all the power were used to offset parasitic drag, then the drag increases with the square of velocity. The ratio of velocities would then be the square root of the ratio of power, or (at)sqrt(80/100), using quattro pro, which is roughly89.44%, resuting in an 80 hp velocity of 119.85 mph if the 100 hp velocity were 134 mph. The other main component of drag, induced drag, decreases with increased velocity but is small at velocities significantly above stall speed, so the actual 80 hp cruise speed would likely be a little less than 119 mph.
Date: Fri, 4 Apr 2008 16:06:05 -0500
Subject: Re: Re: Zodiac XL Cruise Speed with 80HP
Hi Andy,
Sure. Here it is...
v = velocity m/s
Jim
get exact figures.
Jim
Andy Shontz
CH601XL - Corvair
More immediate than e-mail? Get instant access with Windows Live Messenger.
 Filesize:  9.71 KB
 Viewed:  742 Time(s)
 Filesize:  9.84 KB
 Viewed:  725 Time(s)
ashontz
PostPosted: Fri Apr 04, 2008 1:22 pm    Post subject: Re: Zodiac XL Cruise Speed with 80HP Reply with quote
Thanks.
Actually, the 25% more power=10% faster is pretty accurate. Let's say the 80hp speed was 122, 100hp speed would then be 122 x 1.1 = 134.2mph. Scaling backwards, the ratio is .9090909090 on speed and a 20% reduction in power, 100hp down to 80hp.
Would that mean a 65hp VW could push an XL at 110mph? Maybe.
An old boat I used to have at one time had a 140hp Johnson on it, it did 50mph in that configuration. With a 70hp Evinrude, it did 36. That was a measured fact, the boat did in fact top out at 50 with a 140 on it, and it topped out at 36 with a 70hp on it.
140hp X .80 = 112hp x .8 = 89hp x .8 = 71.2hp
50mph x .909090 = 45.5mpg x .909090 = 41.3mph x .909090 = 37.5mph
Damn, those numbers are pretty close. Interesting isn't it.
At some point this would have to cease to be a linear? (logrythmic?) relationship though because I can't imagine a 601Xl going 80mph with a 33hp engine on it. Smile LOL And definitely no 60mph with a 16hp engine on it.
And definitely not 45mph with an 8hp engine on it. But for anyone who just barely wants to get off the ground and keep it local, you could try installing an 8hp Briggs and Stratton and report back how it worked out.
Hi Andy,
Sure. Here it is...
dens = 1.293 kg/m^3 at 0?C and 1 atmosphere
v = velocity m/s
Jim
ashontz wrote:
--> Zenith-List message posted by: "ashontz" <ashontz> (ashontz(at)nbme.org)
get exact figures.
Jim
Andy Shontz
CH601XL - Corvair
PostPosted: Fri Apr 04, 2008 1:22 pm    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
PostPosted: Fri Apr 04, 2008 2:03 pm    Post subject: Zodiac XL Cruise Speed with 80HP Reply with quote
Hi Frank,
Those formulas are correct and are standard . In my first post I noted
some of the problems with the comparison dealing with vectors. One thing
to note is that Cd changes with velocity (particularly close to mach).
At the difference in these velocities the Cd change due to velocity is
insignificant, but the Cd change due to attack angle may be significant.
Drag increases with the square of velocity. Power requirement increases
with the CUBE of velocity. Power =(Fd)(v) and since Fd included a
square..it is now a cube.
Jim
