tanks
slyck(at)frontiernet.net
PostPosted: Fri Mar 21, 2008 5:50 am    Post subject: tanks Reply with quote
Group, here's a thought about gas tank possibilities.
These are very heavy wall plastic, most likely HDPE
They have large openings and some plumbing installed.
The 12V pump may be questionable though.
http://tinyurl.com/29bh7y
BB, sunny and windy up here this morning.
captainron1(at)cox.net
PostPosted: Fri Mar 21, 2008 4:55 pm    Post subject: tanks Reply with quote
Folks I recommend that anyone that wants a custom fuel tank get in touch with the local Boating service folks and have them fabricate you a tank for your exact specs. Its easy inexpensive and made of aluminum. I had both of my tanks fabricated that way and they are strong and exactly as I want them. Each tank, and mine are big at 14 gallons each was about 175 dollars don't know what todays prices are but should not be too much more.
Measure 3 times before you order as you will get exactly what you tell them no refunds. I would to make sure fabricate the model out of cardboard to make sure it fits and is exactly the shape you want, including the fittings and whatever. Only then go and order.
Ron (Arizona)
kugelair.com
ElleryWeld(at)aol.com
PostPosted: Fri Mar 21, 2008 7:42 pm    Post subject: tanks Reply with quote
Now your going to start spraying your crops with your Kolb now this I gotta see J/K
Ellery in Maine
In a message dated 3/21/2008 8:51:15 A.M. Eastern Standard Time, slyck(at)frontiernet.net writes:
--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net>
BB, sunny and windy up here this es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ;   =========================
Create a Home Theater Like the Pros. Watch the video on AOL Home.
PostPosted: Fri Mar 21, 2008 8:29 pm    Post subject: tanks Reply with quote
I am building my own aluminum tank and just as big as I can fit in the mk3 ,so I can stay away from this planet with the kolb dropping syndrome this world sucks Kolbs to the ground LMAO yea right
Ellery
In a message dated 3/21/2008 7:56:19 P.M. Eastern Standard Time, captainron1(at)cox.net writes:
--> Kolb-List message posted by: Ron <captainron1(at)cox.net>
Ron (Arizona)
russ(at)rkiphoto.com
PostPosted: Sat Mar 22, 2008 3:51 am    Post subject: tanks Reply with quote
ElleryYou may find  yourself in the tank-making  business!
On Mar 22, 2008, at 12:25 AM, ElleryWeld(at)aol.com (ElleryWeld(at)aol.com) wrote:
Ellery
In a message dated 3/21/2008 7:56:19 P.M. Eastern Standard Time, captainron1(at)cox.net (captainron1(at)cox.net) writes:
--> Kolb-List message posted by: Ron <captainron1(at)cox.net (captainron1(at)cox.net)>
Ron (Arizona)
---- robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
PostPosted: Sat Mar 22, 2008 6:10 am    Post subject: tanks Reply with quote
If I can find the time to build fuel tanks only for Kolbers I would be willing as I am busy building planes for other guys and building Well Drilling Rigs part time 50 hours a week for a friend
Ellery in Maine
In a message dated 3/22/2008 6:52:00 A.M. Eastern Standard Time, russ(at)rkiphoto.com writes:
Ellery You may find yourself in the tank-making business!
Ellery
Ron (Arizona)
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
olendorf
PostPosted: Sat Mar 22, 2008 6:16 am    Post subject: Re: tanks Reply with quote
I just had an aluminum tank custom made for my Firestar by these guys.
http://www.alumiworx.com/cart/index.php?act=viewProd&productId=23
It was about $180 shipped for my 8 gallon tank. Prices will vary depending on options, size and shipping. I'm pretty happy with it but they left off the mounting tabs. I'm currently recovering my plane so I haven't filled it with fuel yet. I know it doesn't leak water.
I did make a cardboard tank first and that is a must. I found issues I didn't think of when drawing it out on paper.
Fitting the tank
 Filesize:  97.31 KB
 Viewed:  443 Time(s)
Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/
planecrazzzy
PostPosted: Sat Mar 22, 2008 6:25 am    Post subject: Re: tanks Reply with quote
A tank "COULD" hold water , but leak Diesel...
I don't know about Gas....
Gotta Fly...
Mike & "Jaz" in MN
