Gig Giacona
Posted: Mon Mar 17, 2008 1:17 pm Post subject: Need a hole on plexiglass. |
I need to put two 2.5 inch holes in the Plexiglas on my canopy to mount Vista Vents. Any ideas, Tips or blade suggestions.
And yes one of them is to get rid of a crack that developed when mounting the canopy.
601XL Under Construction
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Mon Mar 17, 2008 1:30 pm Post subject: Re: Need a hole on plexiglass. |
Hole saw, slow speed as to not get the plex hot and sticky. A little oil helps too. Make sure its a quality saw and spins true, or you will have a nasty ragged hole.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Mar 17, 2008 1:42 pm Post subject: Re: Need a hole on plexiglass. |
I used a fly cutter, turned by hand. Start on one side and when about half way thru, turn it around and cut from the other side. I back it up with a piece of plywood that has a hole drilled in it the same size as the fly cutter pilot - It helps to support the piece as much as possible.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
ashontz
Posted: Tue Mar 18, 2008 8:46 am Post subject: Re: Need a hole on plexiglass. |
| kmccune wrote: | Hole saw, slow speed as to not get the plex hot and sticky. A little oil helps too. Make sure its a quality saw and spins true, or you will have a nasty ragged hole.
Kevin |
I bet running it backwards would probably work well too. Less chance of grabbing. Kind of like cutting aluminum on a tablesaw. Put the blade on backwards and there's less chance of it grabbing and cuts just as well believe it or not.
kmccune
Posted: Tue Mar 18, 2008 10:11 am Post subject: Re: Need a hole on plexiglass. |
Good idea, I've done that when cutting vinyl siding with the radial arm and it works very well.
Dorothy McCune |
ashontz
Posted: Tue Mar 18, 2008 1:37 pm Post subject: Re: Need a hole on plexiglass. |
Yeah, me too. I was just doing that a few months ago.
To get that initial hole, a straight router bit as a drill bit works well. I used one in my milling machine to drill a hole in plexiglass. Drills great.
| kmccune wrote: | | Good idea, I've done that when cutting vinyl siding with the radial arm and it works very well. |
