It's official
Goto page 1, 2  Next
jmaynard
PostPosted: Mon Mar 17, 2008 2:31 pm    Post subject: It's official Reply with quote
I sent in the deposit on my Zodiac XLi this morning. Now, I get to finish
the paint and interior designs, and wait impatiently for delivery.
The base paint design is on my LiveJournal, at
http://jmaynard.livejournal.com/328864.html . There's still more to be added
to it, in the form of vinyl graphics. Anyone know why green isn't a common
color for aircraft? Also, how much can I do on the wings? I assume that
full-span vinyl strips just behind the leading edge are a Bad Idea for
airflow, but I've seen some on aircraft before. I'm not looking to go hog
wild here, but I do want something.
It'll be one of the best-equipped Zodiacs AMD has built, and that's just the
way I want it. The aircraft will be more capable than me, so I can grow into
it.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
haven
PostPosted: Mon Mar 17, 2008 3:25 pm    Post subject: Re: It's official Reply with quote
because it blends in with the trees if you have a off field landing in the forest. That would be my guess. And a white one would blend into the snow in the winter, That pretty much leaves PINK.
lwinger
PostPosted: Mon Mar 17, 2008 9:14 pm    Post subject: It's official Reply with quote
Jay,
Congratulations on you choice of the 601XL from AMD. From your recent posts on this list, it is clear that you have done your research. Reading your LiveJournal entries it sounds like you've been getting some good stick time in the plane as well.
Please be sure to post photos and performance data as you have it. It would be really interesting to learn what a top-of-the-line 601XL comes with from the factory, if you'd be willing to share.
Larry Winger
601XL/Corvair
Tustin, CA
Working on the rear fuselage
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
planecrazydld(at)yahoo.co
PostPosted: Tue Mar 18, 2008 2:39 am    Post subject: It's official Reply with quote
actually, small spanwise bumps can have a beneficial effect - at the speeds this plane plies I would not worry at all. Just make certain that the surfaces are spotlessly clean and it is down well along the leading edge so that you do not have lifting/peeling. Also, the transfer adhesive commonly used on vinyl graphics is time sensitive as to attachment integrity; it flows to wet the surface over a little while. It would be better if you did not apply and fly.
Jay Maynard <jmaynard(at)conmicro.com> wrote:[quote] --> Zenith-List message posted by: Jay Maynard
http://jmaynard.livejournal.com/328864.html . There's still [quote][b]
jmaynard
PostPosted: Tue Mar 18, 2008 4:51 am    Post subject: Re: It's official Reply with quote
You'd have to twist my arm to get me to not post pictures! Smile I do plan to have a web page with all of the pictures I can think of taking.
My XLi will have all of the airframe options AMD offers except the BRS parachute, the airbag seat belts, and the wing lockers (not because of structural concerns, but because I just couldn't see any use for them). The stack will have a GNS430W with CDI, an SL40, a GMA340, and a GTX330, and there'll also be a mount and wiring for my GPS496. I'll also have a TruTrak Digiflight IIVSG autopilot, and fuel flow sensors for the Dynon EMS. All of that is on top of the comprehensive equipment package that's standard on the XLi. It's a very complete package, and one that I'll enjoy flying.
Jay Maynard, K5ZC
Gig Giacona
PostPosted: Tue Mar 18, 2008 5:25 am    Post subject: Re: It's official Reply with quote
If it's not to late think about this as a reason for the wing lockers. Weight in that position moves the CG a lot less than weight in the rear baggage area.
W.R. "Gig" Giacona
601XL Under Construction
jmaynard
PostPosted: Tue Mar 18, 2008 6:11 am    Post subject: Re: It's official Reply with quote
I don't doubt that...but the problem I have is that they're small enough that I can't think of what I'd put in them. I'm also not completely sure they're weather-tight, although it'd be kinda dumb for them not to be.
Jay Maynard, K5ZC
Jaybannist(at)cs.com
PostPosted: Tue Mar 18, 2008 6:36 am    Post subject: It's official Reply with quote
And with all those Dzus fasteners, not really very handy.
Jay in Dallas
Jay Maynard, K5ZC
http://forums.matronics.com/viewtopic.php?p=170615#170615
Gig Giacona
PostPosted: Tue Mar 18, 2008 7:11 am    Post subject: Re: It's official Reply with quote
True but better than duct-taping a couple of changes of clothes to the wing. Smile
And I will figure out a better fastener sooner or later.
Do Not Archive.
W.R. "Gig" Giacona
agbeyer(at)sbcglobal.net
PostPosted: Tue Mar 18, 2008 7:20 am    Post subject: It's official Reply with quote
Jay,
I have an HDS with the wing lockers in and would not be without them. The wing is a lot thicker than the XL wing, but I would still think about adding them to your plane. I have flown from Oshkosh (Home) to SnF and out West a couple of times with the lockers packed full of stuff as well as the rest of the plane. They will leak a little if there is rain. I have small plastic storage buckets that keeps stuff dry. They are good for tools, oil, parts, tie-downs, canopy cover, cleaning stuff for the plane, tent,etc. It takes only a few seconds to open the Dzus fasteners. They are very handy.
AL from Oshkosh
jmaynard
PostPosted: Tue Mar 18, 2008 7:42 am    Post subject: Re: It's official Reply with quote
This brings up a related question: I have not yet seen a complete set of weight and balance numbers for any Zodiac at all. Can someone pass along data on their plane? I know mine will be different, but right now, I have no feel for it at all.
Jay Maynard, K5ZC
Gig Giacona
PostPosted: Tue Mar 18, 2008 7:48 am    Post subject: Re: It's official Reply with quote
I'm no where close to doing weight and balence but if I just sent a deposit to AMD I think I'd give them call and see if you could get a copy of the POH now.
W.R. "Gig" Giacona
jmaynard
PostPosted: Tue Mar 18, 2008 7:55 am    Post subject: Re: It's official Reply with quote
I've seen the POH...and the W&B numbers aren't filled in until they produce the specific book for the aircraft. That's a good idea, though, as I can do other things like make laminated checklists.
Jay Maynard, K5ZC
craig(at)craigandjean.com
PostPosted: Tue Mar 18, 2008 8:06 am    Post subject: It's official Reply with quote
Gary Ray's very complete W&B spreadsheet contains the numbers for his
Corvair-powered XL. It is under "Builder's resources" on www.ch601.org here:
http://www.ch601.org/resources/W&B/ZodiacXLWBFinal.xls
-- Craig
jmaynard
PostPosted: Tue Mar 18, 2008 8:36 am    Post subject: Re: It's official Reply with quote
Just what I was looking for. Thanks!
Jay Maynard, K5ZC
Larry Hursh
PostPosted: Wed Mar 19, 2008 11:56 am    Post subject: It's official Reply with quote
Well I plan on putting my 4 ton hydraulic jack, tie downs, tie down stakes, extra quarts of oil, a set of chains if I need them, a couple of bungee cords, extra grease (in case my wheels stop going around and around), a couple of cases of Diet Coke, some ice for our "in-flight" lunch to keep the pop cold and lunch meat cold, probably a couple of bags of groceries, our luggage (I'd hate to overload the baggage area behind the seat yah know) and our pillows. That should about round out everything we'll need for our over night trips. I just wished I would have put on the extra fuel tanks so I can fly further without having to stop and refueling too.......
(NOT!)
LH
Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered
View user's profile Send private message Send e-mail Yahoo Messenger
notsew_evets(at)frontiern
PostPosted: Wed Mar 19, 2008 12:21 pm    Post subject: It's official Reply with quote
You ARE kidding, yes.???
A four ton jack ? I dont think so, Larry...
Maybe a one half ton but shirley not a four ton...
SW
swater6
PostPosted: Wed Mar 19, 2008 12:38 pm    Post subject: Re: It's official Reply with quote
Don't call me Shirley........
 Filesize:  9.74 KB
 Viewed:  770 Time(s)
601 XL kit N596SW reserved
Tail, control surfaces and both wings complete. Now working on fuselage
www.scottwaters.com
ch701builder
PostPosted: Wed Mar 19, 2008 12:39 pm    Post subject: It's official Reply with quote
Also, a case of Diet Coke weighs less than a case of Coke (less calories) and if you fly high enough, you don't need ice!!! Only need chains over high mountain passes in the Winter. (not really needed in the Summer) so plan your trips accordingly.
KA
[quote] [quote] ---
hansriet
PostPosted: Wed Mar 19, 2008 9:23 pm    Post subject: Re: It's official Reply with quote
Everybody knows the 601 is front wheel drive. So you only need one chain.
DO NOT ARCHIVE
Goto page 1, 2  Next
Page 1 of 2
