ghiggins(at)cirruscomms.c Guest
Posted: Sat Mar 15, 2008 3:31 pm Post subject: Trials of Fitting (doors) |
Hi Fred,
Welcome to the joys of building!
The real "pissed off" feeling comes when, after all the meticulous fitting
and fiddling that we perfectionists tend to perform, you find that the thing
changes after some time in the sun, with the corners cocked up, looking as
though you threw it together in an afternoon, without wearing your
glasses!!!
Lesson - make sure you make some provision to prevent the pressure of the
gas strut deforming the door under warm conditions, as happened to mine,
built to original spec's. There are a few ways to do this.
Regards Graham Higgins in Oz.
Posted: Sat Mar 15, 2008 4:01 pm Post subject: Trials of Fitting (doors) |
Graham
are you aware of Ted Gladstones fix for this? His solution removes the
load from the door and the fuselage, which probably both move.
Graham
Graham Higgins wrote:
<ghiggins(at)cirruscomms.com.au>
Hi Fred,
fitting and fiddling that we perfectionists tend to perform, you find
that the thing changes after some time in the sun, with the corners
cocked up, looking as though you threw it together in an afternoon,
without wearing your glasses!!!
the gas strut deforming the door under warm conditions, as happened to
mine, built to original spec's. There are a few ways to do this.
Graham Singleton
Tel: +441629820187
Mob: +447739582005
130.26 KB |
279 Time(s) |
Posted: Sat Mar 15, 2008 8:54 pm Post subject: Trials of Fitting (doors) |
Graham, Kingsley Hurst has done the same mod to his classic mono
out a Taroom. Last time i was out there it was about 40c and his doors looked perfect. The way he had the pivot points set up for this the strut
seem to be providing a moderate amount of hold down pressure on the door. I believe I will do doing the same mod on mine.
regards
Craig
Visit - www.EuropaOwners.org
Posted: Sun Mar 16, 2008 4:40 pm Post subject: Trials of Fitting (doors) |
I think Kingsley has Ted's drawings, ask him, it's fairly tricky. Ted
will let you have them I'm sure
Graham
raggi6771 wrote:
regards
Craig
Graham Singleton
Tel: +441629820187
Mob: +447739582005
fklein(at)orcasonline.com Guest
Posted: Sun Mar 16, 2008 4:45 pm Post subject: Trials of Fitting (doors) |
Graham Singleton,
Do you know whether or not the Ted Gladstone gas strut mod preceeded
the factory Mod 66, or does it address issues which the factory mod
does not solve?
Fred
On Saturday, Mar 15, 2008, at 16:00 US/Pacific, Graham Singleton wrote:
<Ted Gladstone's door strut.jpg>
believed to be clean.
130.26 KB |
254 Time(s) |
Posted: Sun Mar 16, 2008 4:53 pm Post subject: Trials of Fitting (doors) |
Ted's is the most elegant design I've seen, pity the factory didn't take
it up, it was offered but Andy was too busy at the time.
The factory mod still strains the door (but lesas) Ted's does not.
Graham
Fred Klein wrote:
| Quote: | Graham Singleton,
Do you know whether or not the Ted Gladstone gas strut mod preceeded the
factory Mod 66, or does it address issues which the factory mod does not
solve?
Fred
Graham Singleton
Tel: +441629820187
Mob: +447739582005
jrgowing(at)bigpond.net.a Guest
Posted: Sun Mar 16, 2008 10:55 pm Post subject: Trials of Fitting (doors) |
fellow Builders
And I am happe that I have used Kingsley's drawings to use Ted's mod on my
doors -
but at the rate I am going, it will be a while until I see them work on an
aerodrome!
JR (Bob) Gowing UK Kit 327 with mods in Oz
