I'm stumped
Deems Davis
PostPosted: Wed Mar 01, 2006 4:54 pm    Post subject: I'm stumped Reply with quote
I'm stumped (not a rare instance). I'm attaching the WD-1004 Nose Gear
Tension Fittings to the F-1048 Fwd Fusalage Ribs prior to riveting the
assemblies to the Firewall (Plans Sec 27-4 step 7). There are 50 AN470
AD 4-5 rivets that get set in this section . There are ALSO 8 AN470 AD
4-6 rivets that are the most forward (closest to the firewall) I can't
seem to figure a way to get a rivet gun on these 8 rivets, unless I move
the shop head to the other (inside) side of the rib. Anybody got have a
tip here?
Deems Davis # 406
Fuse
http://deemsrv10.com
Rick S.
PostPosted: Wed Mar 01, 2006 6:28 pm    Post subject: I'm stumped Reply with quote
Deems,
You will have to trim the firewall stiffeners. Go up about 1" and over a 1/2" shaped like a 30/60 triangle, and trim it enough to get your offset rivet set on the head...it's a pain. I'll do a picture and email to you in a bit...dinner time.
Rick S.
40185
Finishing kit inventory
Rick S.
RV-10
40185
wcurtis(at)core.com
PostPosted: Thu Mar 02, 2006 9:00 am    Post subject: I'm stumped Reply with quote
[quote]You will have to trim the firewall stiffeners. Go up about 1" >and over a 1/2" shaped like a 30/60 triangle, and trim it enough >to get your offset rivet set on the head...it's a pain. Whoa there! Before you go trimming firewall stiffeners, check on page 27-4, Step 7. Van’s recommends you place the shop heads on the outboard side of the WD-1004 fitting. This recommended direction does not provide for the most finish look, but I always try to place the manufacturer’s head on the thinner material. In this case it is the F-1048-L/R. Van’s rarely specifies the direction of the rivet head but in this case they did. If you look at my page at the below link, I did a compromise. I followed the recommendation except the top three rows of rivets. http://wcurtis.nerv10.com/08fuselage/fuselage03f.html William Curtis http://nerv10.com/
Rick S.
PostPosted: Thu Mar 02, 2006 10:04 am    Post subject: I'm stumped Reply with quote
William,
Sorry I may have been thinking about a different section, the area I was talking about is in the photo, it is the most forward rivet in the 1002/1003 brackets. I may have jumped the gun, the are your photos show I followed the plans regarding rivet direction and had no issues.
Rick S.
40185
 Filesize:  370.44 KB
 Viewed:  432 Time(s)
Rick S.
RV-10
40185
Rick S.
PostPosted: Thu Mar 02, 2006 10:10 am    Post subject: I'm stumped Reply with quote
Deems,
Sorry I was thinking of a different area, William posted the correct respons to double check your rivet direction. My mind is still bouncing after riveting the 1002/1003 to the lower forward longerons. That is where I was refering to regarding the trimming of the stiffener. See later post for what I was thinking.
Rick S.
40185
Rick S.
RV-10
40185
Deems Davis
PostPosted: Thu Mar 02, 2006 1:00 pm    Post subject: I'm stumped Reply with quote
Thanks for the responses, now, if i could only learn to read............
Deems Davis # 406
Fuse
http://deemsrv10.com/
Rick wrote:
Deems,
Rick S.
40185
