3-view, TD, pdf
Jaybannist(at)cs.com
PostPosted: Sun Mar 16, 2008 9:21 am    Post subject: 3-view, TD, pdf Reply with quote
3-View-TD.pdf
 Filename:  3-View-TD.pdf
 Filesize:  21.43 KB
 Downloaded:  638 Time(s)
Wingrider
PostPosted: Mon Mar 17, 2008 5:01 pm    Post subject: Re: 3-view, TD, pdf Reply with quote
Jay do you have a dwg of the tail dragger?
Rich Whittington
Tullahoma, TN
Zenith 601HDS
Corvair 3 Liter 120HP
PostPosted: Mon Mar 17, 2008 5:43 pm    Post subject: 3-view, TD, pdf Reply with quote
Rich, Please go to www.ch601.org. You'll find the drawings under "Builder Resources". If you can't find what you need, get back to me.
Jay
Rich Whittington
Tullahoma, TN
Zenith 601HDS Under Construction
http://forums.matronics.com/viewtopic.php?p=170513#170513
dalemed
PostPosted: Tue Mar 18, 2008 7:04 am    Post subject: Re: 3-view, TD, pdf Reply with quote
Be aware that the main gear isn't located properly in that drawing on the ch601.org website. It should be located near the leading edge of the wing.
Dale
Zenith Zodiac CH650
