DAquaNut(at)aol.com Guest
Posted: Sat Mar 15, 2008 9:48 pm Post subject: New "Kolbee" ... New to the Forum |
Joe,
Welcome to the list. congrats on your new Kolb . The biggest difference between your Kolb and what you are used to, is it has more drag and slows down quickly. You dont want to flare it until you are close to the ground. The closer the better. Actually you hardly flare at all. Just fly it to about a foot off the ground and back of the throttle. If you flare like a conventional craft you are asking for trouble.
Good Luck,
Ed Diebel ( Firefly 62 In Houston) 80* today
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
ElleryWeld(at)aol.com Guest
Posted: Sun Mar 16, 2008 4:14 am Post subject: New "Kolbee" ... New to the Forum |
Joe
Welcome to the list , and you got a Great little plane there I am sure you will really enjoy it. will you post a Pic of it so I can put a Plane with a name I hear you on the hurry up and get here warm weather
Ellery in MAINE
In a message dated 3/16/2008 12:18:57 A.M. Eastern Standard Time, jreaves57(at)yahoo.com writes:
| Quote: | --> Kolb-List message posted by: "Hose.A" <jreaves57(at)yahoo.com>
Hi everyone,
The name is Joe and I hail from Tyler, Texas. I am new to the forum and new to ultralights. Just bought a 2002 Kolb Mark III and really anxious to get some time in it. I have a Commercial, Instrument, Multi-engine and CFI, but this will be a whole new learning experience for me.
Hurry up and get here, warm weather!
HoseA
http://forums.matronics.com/viewtopic.php?p=170128#170128
dhkey(at)msn.com Guest
Posted: Sun Mar 16, 2008 6:06 am Post subject: New "Kolbee" ... New to the Forum |
Joe,
I live at F69 stop by sometime, I can get you fuel. Congradulations!
David
| Quote: | Subject: New "Kolbee" ... New to the Forum
Date: Sat, 15 Mar 2008 22:14:15 -0700
Hi everyone,
HoseA
NeilsenRM(at)comcast.net Guest
Posted: Sun Mar 16, 2008 10:15 am Post subject: New "Kolbee" ... New to the Forum |
Joe
As Ed has suggested your biggest problem is landing. Your experience will serve you poorly. On your first landings keep the power maybe on 25% till you are within less than a foot of the ground. Then and only then cut the power. Also don't use flaps at all. As you get more experience SLOWLY reduce the power you set for approach or set one notch of flap. Don't do both at the same time. In fact you may be better off adding a bit more power the first time you use one notch of flaps. Some of us still carry some power with lots of experience. I like to carry some power because landing with one notch of flaps with some power will feel just like no power (engine out) with no flaps. I know this first hand. Some of us never use full flaps other than for brief periods on approach to hit the landing point you want. There is one of our members that uses full flaps and power off on all his landings but I would wait for that after your first thousand landings and even then approach it with added power. There will be those that will tell you I'm being too conservative but most GA pilots will have problems if they move too fast to flaps and no power.
Rick Neilsen
Redrive VW powered MKIIIC
Hose.A
Posted: Sun Mar 16, 2008 10:40 am Post subject: Re: New |
Thanks everyone for the advice on landing the Kolb. I intend to get a few hours dual instruction before venturing out on my own.
Per request, here is a pic of my "new" bird:
98.05 KB |
866 Time(s) |
118.28 KB |
897 Time(s) |
_________________ HoseA |
Posted: Sun Mar 16, 2008 11:51 am Post subject: New "Kolbee" ... New to the Forum |
new to ultralights. >
Hi Joe:
Welcome to the world of little airplanes.
We have a lot of fun building and flying these little guys.
_________________ John Hauck
Titus, Alabama |
Posted: Sun Mar 16, 2008 12:26 pm Post subject: New "Kolbee" ... New to the Forum |
Joe:
Where is your center section?
Kolbs were designed to fly with centersections to cover the area between the
wing sections. They fly much better with center section installed.
Titus, Alabama |
Posted: Sun Mar 16, 2008 2:33 pm Post subject: New "Kolbee" ... New to the Forum |
after seeing the Kolbs on Barnstormers that is the one I thought you would have purchased thinking it wasn't to far from where you live it sure looks like a nice one I hope you have many hours enjoying flying in it
Ellery in Maine
In a message dated 3/16/2008 1:43:31 P.M. Eastern Standard Time, jreaves57(at)yahoo.com writes:
russ(at)rkiphoto.com Guest
Posted: Sun Mar 16, 2008 3:56 pm Post subject: New "Kolbee" ... New to the Forum |
HoseA -- where's the pic?
On Mar 16, 2008, at 4:22 PM, John Hauck wrote:
> HoseA
Joe:
between the wing sections. They fly much better with center
section installed.
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Sun Mar 16, 2008 4:52 pm Post subject: Re: New |
Welcome Joe,
Tyler, TX ain't to fer from me. Maybe I'll stop in and check on you one day. It would be a good leg stretcher for me.
Don't rush it. Landing the Kolb is just different due to the low inertia in the flare. Not hard just need to be aware. If you get comfortable with that, work on short field over obstacles (trees). We have an informal gathering of Kolbs, second weekend in July at Nauga Field (LS35). Come visit if you want. We pass a good time!
You'll find some of the best folks in the world fly Kolbs (not 100% though ). Some of my best times are flying and camping with other Kolbers.
E-mail me direct if I can help. We can talk about that center section if you have questions.
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
Possums
planecrazzzy Guest
Posted: Sun Mar 16, 2008 5:23 pm Post subject: Re: New |
Is That a 582 on yer Bird ?
Gotta Fly...
Mike & "Jaz" FSII / 503 / N381PM
58.72 KB |
842 Time(s) |
Posted: Sun Mar 16, 2008 5:39 pm Post subject: New "Kolbee" ... New to the Forum |
I respectfully disagree with the idea that you should not use flaps on landing.
[quote] From: NeilsenRM(at)comcast.net
Subject: Re: New "Kolbee" ... New to the Forum
Date: Sun, 16 Mar 2008 14:10:28 -0400
Joe
Rick Neilsen
Posted: Sun Mar 16, 2008 6:47 pm Post subject: New "Kolbee" ... New to the Forum |
David
Ok. So tell us why.
Rick Neilsen
Posted: Sun Mar 16, 2008 8:05 pm Post subject: New "Kolbee" ... New to the Forum |
Because the dreaded Kolb drop, or stall is what it used to be called occurs a little later and a little slower which gives the pilot a little more time to make adjustments in the landing environment. Kolb steering is a bit easier to tackle the slower you are going. It's the way that I would teach it.
Date: Sun, 16 Mar 2008 22:42:15 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass EC_BODY.hmmessage {font-size:10pt;font-family:Tahoma;} David
Ok. So tell us why.
Rick Neilsen
Hose.A
lcottrell
Posted: Sun Mar 16, 2008 8:22 pm Post subject: New "Kolbee" ... New to the Forum |
aoldman(at)xtra.co.nz Guest
Posted: Sun Mar 16, 2008 10:44 pm Post subject: New "Kolbee" ... New to the Forum |
I will add my two bobs worth here on how I do it. Two up long finals ,60mph at about 300 to 500 agl depending on where the runway is, reduce speed to 55mph and full flap . Use the throttle/side slip to put yourself on the spot you have picked to touch down. Most times from 300 ft there is no need to touch the throttle again. My suggestion for some one landing a MK111c for the first few times would be to make all approaches under power with plenty of flap. Doing it this way will get you out of trouble if you miss judge something at the last moment . I always take off with 50% flap,lift the tail about 30 mph and rotate at 50 to 55 hold the nose down momunteraly then point the nose at the sky and maintain a steady 55 /60 to 1000 ft.
Flying solo I reduce the speeds by about 5mph.I also prefer to use grass to land on .My first couple of attemps of taking off on a sealed runway had much the same results as you have explained .To work out the speeds for rotating I simply judge how far aft I have to pull the stick with a givin AUW, If you try and rotate too slow the stick will be right back and you will find you need to push it forward to get your best climb out speed. After some practice you will be able to judge where the stick needs to be with a given load. Practice.practice.practice. A very forgiving and fun aircraft, just always remember if you pull the stick back without either speed or power you are going to stop flying .It is not forgiving at real slow speeds close to the ground.There are others who may disagree with what have said here and thats OK. We all tend to work out what suits us and develope our own operating practices from there.
Stay safe up there
Tony from down under
rowedenny
Posted: Mon Mar 17, 2008 2:53 am Post subject: New "Kolbee" ... New to the Forum |
OK, I can't stand it any more- Who is Hose,B
Larry C
Ahhh, nevermind. :-p
Denny
That was a close one!
biglar
Posted: Mon Mar 17, 2008 3:04 am Post subject: New "Kolbee" ... New to the Forum |
After they're all done with you, you been HoseD.
Do not Archive.
Denny Rowe wrote:
> Larry C
> do not archive
Denny
Larry Bourne
Santa Fe, NM
www.gogittum.com
www.gogittum.com/blog
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
