panamared3(at)brier.net Guest
Posted: Wed Mar 01, 2006 9:45 am Post subject: Confidence in Van's Designs, Previous subject: I have nev |
| Quote: | I HAVE TO TELL YOU THAT I HAVE NEVER SEEING SO MANY POSTINGS AS THE ONE
FOR THE S.B. TANKS..
WHO CARES... ALL THESE PEOPLE COMPLAINING , AND HOWLING .. DON'T DO IT.
NO ONE IS FORCING ANY ONE TO DO IT..
I DID MINE, THIS PAST WEEK END. I HAVE HAD TO REMOVE ONE TANK BEFORE
DUE TO A FUEL LEAK... NO BIG DEAL..
WARNING: If you don't want to get pissed off, please delete NOW!!!
I will tell you what the big deal is! This is a mandatory SB and I for one
feel that I should complete it before my next flight. Despite the SB
instructions this task will take me at least 20-30 hours of work. At this
time I do not have the time available to do this until sometime in
April. Which means I will not be flying until it is done in April. That
might not be a big deal for you, but it is for me.
I have read the instructions and for my RV they are flat out WRONG!!! No
way I can follow Vans instructions. One point is that on the inverted tank
the access plate is on the rear tank bulkhead. So this tank must come off
the airplane. My inverted fuel tank was built in accordance with the Vans
plans and construction manual. Once again wrong instructions might not be
But what the real BIG DEAL is that some of us have lost confidence
in Van's construction designs. Before, I felt that if Van designed it that
way, that was the the best way to build it. But now I feel like I have to
question everything in my aircraft.
So what else have I built according to the plans that may now be
wrong? FYI wing tanks have been on RVs for around 30 years, this is not a
new untried design or technique.
This is a significant emotional event for me, in other words, this is a BIG
DEAL!
I realize that other airplanes have these SBs and ADs. So that makes it
all right?
As for Lycoming crankshafts, it does not affect my engine, but this really
upsets me also. If I bought my Lycoming from Wall Mart I would expect
these types of problems, but at the price I paid for my engine I expect a
little bit better quality control. But on the other hand, as bad as
Lycoming quality control is, we just keep on buying them. We are our own
worst enemy.
RV6 NightFighter
jpl(at)showpage.org Guest
Posted: Wed Mar 01, 2006 10:22 am Post subject: Confidence in Van's Designs, Previous subject: I have nev |
Maybe the fact that everyone in the industry, from time to time,
needs to modify their design in this fashion should tell you something.
It's a complex problem, and no one, no matter how skilled, is able to
envision absolutely everything that can go wrong.
For weight and complexity reasons, a designer is going to keep his
design as simple as possible to safely fulfill the aircraft mission.
You add complexity only for good reason. Which means there are a lot
of judgement calls to make. And clearly, this particular call is 98%
right. The number of problems in this area have been small, but not
zero.
I guess I don't know what you expect. Perfection? It doesn't exist.
-Joe
On Mar 1, 2006, at 12:39 PM, Bob have never seeing so many sb wrote:
| Quote: | But what the real BIG DEAL is that some of us have lost confidence
it that
have to
| Quote: | I realize that other airplanes have these SBs and ADs. So that
makes it
all right?
jsflyrv
Posted: Wed Mar 01, 2006 3:14 pm Post subject: Confidence in Van's Designs, Previous subject: I have nev |
If I was you I would junk that piece of S**t rght now. I am sure that the design is so bad that it will fall apart the next time you get in it. NO WAY AM I EVER GOING TO FLY MINE AGAIN. You have made me aware that the thing is junk
and Van's does not have a clue what they are doing. I sure wish that I had known this 17 years ago when I built mine. I would not have flown it all these years if you had told me they did not know how to design the most popular homebuilt in the world..
From: Bob <panamared3(at)brier.net> have never seeing so many sb
many sb
DEAL!
all right?
worst enemy.
RV6 NightFighter
From: Bob panamared3(at)brier.net have never seeing so many sb
-- RV-List message posted by: Bob <PANAMARED3(at)BRIER.NET>have never seeing so
many sb
inst
feel like I have to
DEAL!
all right?
worst enemy.
RV6 NightFighter <BR
