Keyed Master Switch?
andrewbutler(at)ireland.c
PostPosted: Fri Mar 14, 2008 6:45 am    Post subject: Keyed Master Switch? Reply with quote
All,
I plan on a PUSH Button Start and Dual Electonic Ignition. Can anyone help with a method of enabling "key start" access to ignition/power?
I have dual paths to each ignition, so need four switches (to enable pre-flight checks of each path), so the documented adapted mag key start switch option won't work.
I can't get fully comfortable with a fully live system being just a flip of a switch away....... See attached to get the idea.
Best regards,
Andrew Butler
RV 71700 - West of Ireland.
Fueslage (right way up!)
Dual_Batt_&_Alt_-_8Amp_Backup_-_Split_Bus.pdf
 Filename:  Dual_Batt_&_Alt_-_8Amp_Backup_-_Split_Bus.pdf
 Filesize:  273.71 KB
 Downloaded:  694 Time(s)
dennis.glaeser(at)eds.com
PostPosted: Fri Mar 14, 2008 7:56 am    Post subject: Keyed Master Switch? Reply with quote
Consider putting a keyed switch in the Push Button Start circuit. If
the key isn't on, the start button doesn't work! One switch does the
trick and it doesn't put another switch (point of failure) in any of
your other critical circuits.
Your ignition systems may be live if their switches are flipped, but
nothing happens without the starter.
Dennis Glaeser
RV7A - Subaru H6 - DAR inspection next week!
Best regards,
Andrew Butler
ctbecker
PostPosted: Fri Mar 14, 2008 11:12 am    Post subject: Keyed Master Switch? Reply with quote
Dennis has the right idea, especially in light of all the
emphasis on '2 locks'. My 8A will have a key switch
between the battery and the starter switch. The actual
starter switch will be on the stick, controlling a relay
in the starter circuit.
Charlie Becker
N464CB(r) 8A(e)
Finishing
On Fri, 14 Mar 2008 11:51:42 -0400
circuit. If
switch does the
failure) in any of
flipped, but
Dennis Glaeser
ignition/power?
switches (to enable
being just a flip
Best regards,
Andrew Butler
Un/Subscription,
Forums!
Admin.
Terry Watson
PostPosted: Fri Mar 14, 2008 12:55 pm    Post subject: Keyed Master Switch? Reply with quote
My plan has been to put a simple toggle switch in the baggage compartment
that disconnects the starter switch. Hopefully this plus a canopy lock will
meet the 2 lock requirement. The baggage compartment will also have a lock.
I wonder how many times I will get all strapped in before I realize I
haven't enabled the starter switch.
Terry
RV-8A wiring
mprather(at)spro.net
PostPosted: Fri Mar 14, 2008 1:44 pm    Post subject: Keyed Master Switch? Reply with quote
Do you plan to put a guard on the switch (or cover) to keep loose items in
the baggage compartment from bumping it? I suppose that in flight you
probably won't have to engage the starter ever should that happen. If you
fly the plane long enough without a guard on that switch, you'll
eventually be in a situation where you can't figure out why you can't
engage the starter - after giving somebody a ride maybe, or trying to
restart after a fuel stop..
Will the switch be in a place where it interferes with loading things into
the baggage compartment? Will you have to unload anything form the
compartment in order to gain access to the switch?
Matt-
<terry(at)tcwatson.com>
will
lock.
Terry
RV-8A wiring
Terry Watson
PostPosted: Fri Mar 14, 2008 3:57 pm    Post subject: Keyed Master Switch? Reply with quote
Those are all good considerations, but having it on the starter circuit
rather than ignition makes them a little less critical. The switch guard is
probably pretty important. I would not expect to always use the switch to
disconnect the starter when leaving the airplane, but more for away from
home, overnight -- just one more safeguard, and of course one more point of
possible failure.
I am willing to be convinced that it is not a good idea.
Terry
Dennis Glaeser
PostPosted: Fri Mar 14, 2008 5:49 pm    Post subject: Keyed Master Switch? Reply with quote
Why not a key switch in a more convenient (in the cockpit somewhere)
location? It doesn't have to be on the panel, maybe tucked away somewhere,
but reasonably easy to access. Then no post strap-in remorse, and if you use
the baggage compartment much at all, I predict you'll be removing or
relocating that switch before long.
If you are in a locked hangar, you probably won't use it unless you're away
from home.
Believe me, you're convenience and ease of use is most important.
Dennis
Terry
RV-8A wiring
PostPosted: Sat Mar 15, 2008 5:30 am    Post subject: Keyed Master Switch? Reply with quote
Hi Charlie,
What type of switch are you using and where did you source it?
Cheers, Andrew.
[quote]---
Mark Sletten
PostPosted: Sat Mar 15, 2008 5:51 am    Post subject: Keyed Master Switch? Reply with quote
Why not just use a standard keyed starter switch? Get rid of all the other
push button/toggle switches in the circuit. Power your electrical system
thru a standard toggle if you like and just use the starter side of the
keyed switch in the starter circuit.
Mark
Mark Sletten
Legacy FG N828LM
http://www.legacyfgbuilder.com
klehman(at)albedo.net
PostPosted: Sat Mar 15, 2008 6:51 am    Post subject: Keyed Master Switch? Reply with quote
Automotive and farm suppliers sell good key switches for around $12 and
marine suppliers (at about twice the price) as well. Typically rated for
a 25 amp starter solenoid load. I use one for the battery master and the
spring loaded position cranks the engine. I like the fact that with the
key in my pocket nobody can crank the engine accidentally, and that from
cars we subconsciously associate keys with cranking. Also I think there
is very little chance of the circuit staying energized after cranking
since my fingers can force it back from the crank position even if the
spring fails or the contacts try to weld. Of course my starter solenoid
can still physically stick, but not the switch I hope.
Ken
Mark
Terry Watson
PostPosted: Sat Mar 15, 2008 8:31 am    Post subject: Keyed Master Switch? Reply with quote
Think of it this way: I prefer combination locks to keyed locks because the
latter requires that I have the proper physical key with me while a
combination lock requires only that I know how to open it. What I am
proposing amounts to a combination lock on the ignition: you just have to
know where the switches are. Locking the baggage compartment where the
disconnect switch is located is that additional security feature that we are
now required to have.
When I was in college I bought a sad looking '50 Chevy sedan for $60. It
turned out to be a great car until I ran it low on oil and threw a rod, but
one of the great features was the ignition switch. Key use was optional. You
could turn it to the left with the key in it and remove the key and it was
locked, or you could just remove the key without turning it to the left and
it was still an ignition switch but didn't require a key.
Yes, canopy and baggage compartments will still require a key. My current
Mazda MX-5 only requires that I have the key in my pocket and it
"recognizes" me and allows me to open the doors or trunk and start the
engine. But that's way more complex than I want to go with my airplane.
Terry
steve(at)newtech.com
PostPosted: Sat Mar 15, 2008 10:50 am    Post subject: Keyed Master Switch? Reply with quote
I like the idea of a shorting plug that will short the mag p leads to
ground. Insert the plug to disable the airplane. Remove the plug to
fly. You really are not adding anything to fail in flight. I will only
be using it when away from my home field. Simple, cheap and relatively
free from unintended consequences (I think).
Steve Eberhart
RV-7A, Wiring up everything so I can finally fly this thing.
Andrew Butler wrote:
All,
