steve2(at)sover.net Guest
Posted: Thu Mar 13, 2008 7:03 am Post subject: New Fuel Servo AD? |
New Emergency AD.
RSA-5 and RSA-10 servos....... Precision Airmotive (They holding the certificate for the servos now?)
No flight until compliance.
The way the AD is written, it would seem repetitive every 50 hours with no means of terminating the inspection requirement.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/0/2321ADE8B9025A138625740A00622E71?OpenDocument
Steve
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
2008-06-51_Emergency.pdf |
23.81 KB |
250 Time(s) |
Posted: Thu Mar 13, 2008 7:24 am Post subject: New Fuel Servo AD? |
Ok, P.S.......
Here's the Service Bulletin. It has a picture of the affected part.
Our servo doesn't even have the affected hex plug in the regulator cover........
Steve
PRS-107%20Rev1.pdf |
486.15 KB |
255 Time(s) |
kamala(at)MSN.COM Guest
Posted: Thu Mar 13, 2008 7:45 am Post subject: New Fuel Servo AD? |
which servo is this? gmc
[quote] From: steve2(at)sover.net
Subject: Commander-List: New Fuel Servo AD?
Date: Thu, 13 Mar 2008 10:59:26 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass EC_BODY.hmmessage {font-size:10pt;font-family:Tahoma;} New Emergency AD.
Steve
Posted: Thu Mar 13, 2008 8:14 am Post subject: New Fuel Servo AD? |
In our application its an IO-540. As far as I know, these things are everywhere...... An awful lot of stuff runs on RSA-5 and -10 Bendix servos........ But we don't even have the plug they're talking about.
I did find the spreadsheet that lists the individual servos the 'Service Bulletin' refers to. I'll read the AD to see if the Service Bulletin list applies, but the short of it is this......
"The listing in this column shows all RSA-5 and RSA-10 model fuel injection servos manufactured or rebuilt by Precision Airmotive between 8/22/06 and 3/7/08. Please note that there may be other servos that are affected by service bulletin PRS-107 if they were overhauled or repaired after 8/22/06"
But I've got to get some work done before I can look at this stuff again......
The good news is it appears to be restricted to a couple year window when the servos were rebuilt or repaired.........
PRS-107_Serial_Number_Listing.xls |
638.5 KB |
205 Time(s) |
dowens(at)aerialviewpoint Guest
Posted: Thu Mar 13, 2008 1:33 pm Post subject: New Fuel Servo AD? |
Steve...
Invaluable information as always guys... Thanks for the heads up... It applied to our Navajo... No problem this time... we'll see the next 50 hrs... Thanks again!!!!!
David Owens
Aerial Viewpoint
N14AV
AC-500A-Colemill
