Possums
Posted: Wed Mar 12, 2008 6:19 pm Post subject: Flying with VGs |
Shot some more videos this afternoon.
I'll keep the clips shorter - so as not to bore you all.
I mounted a new Hall ASI close to the camera.
It goes from 0 to 55 mph. They are very accurate in clean air.
It was easy to read in the original clip (32MB), but hard to see
after it was uploaded to Goggle. Guess I need to put it closer to the camera
next time.
Anyway - here is a clip flying at 25 mph at about 4200 RPM.
http://video.google.com/videoplay?docid=8643180947591432536&hl=en
51.76 KB |
763 Time(s) |
_________________ Possum |
Possums
Posted: Wed Mar 12, 2008 6:33 pm Post subject: Flying with VGs |
Here is a clip flying at about 5800 RPM with the
stick pulled all the way back to the seat.
It is hard to stall with full power unless you pull
the stick back pretty quick and make it.
http://video.google.com/videoplay?docid=-8361300167482330203&hl=en
33 KB |
725 Time(s) |
Possums
Posted: Wed Mar 12, 2008 6:38 pm Post subject: Flying with VGs |
Here is our field - it's getting kind of crowded with all the
new houses they've built next to it. But the new neighbors don't
seem to mind - so far. Just gotta watch those antennas.
http://video.google.com/videoplay?docid 63159682459782825&hl=en
53.14 KB |
741 Time(s) |
Possums
Possums
ElleryWeld(at)aol.com Guest
Posted: Thu Mar 13, 2008 3:41 am Post subject: Flying with VGs |
Hey there Possum you say in this pic Video it was a clean stall break the Hall indicator is indicating 35 I had a firestar that weighed in at 338 dry and did not have VG's and it would stall under 30 indicated good thing I didn't put the VG's on ...chuckle ...chuckle
Ellery in Maine sick of all this snow and ready for spring
In a message dated 3/12/2008 10:46:51 P.M. Eastern Standard Time, possums(at)bellsouth.net writes:
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Possums
Posted: Thu Mar 13, 2008 6:33 am Post subject: Flying with VGs |
At 07:38 AM 3/13/2008, you wrote:
| Quote: | Hey there Possum you say in this pic Video it was a clean stall break the Hall indicator is indicating 35 I had a firestar that weighed in at 338 dry and did not have VG's and it would stall under 30 indicated good thing I didn't put the VG's on ...chuckle ....chuckle
You've gotta remember that I'm not dragging the plane thru the
air with three notches of flaps either. I don't even have flaps or flaperons.
I don't even have the old "barn door" style ailerons on this plane.
Jim ODay
Joined: 09 Jul 2007 Posts: 61 Location: Fargo North Dakota
Posted: Thu Mar 13, 2008 6:52 am Post subject: Re: Flying with VGs |
Wow Possum! Great demo video.
The steep turns are very impressive. Thanks for sharing them.
Fly safe,
Jim
_________________ Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Possums
Posted: Thu Mar 13, 2008 1:22 pm Post subject: Re: Flying with VGs |
| Jim ODay wrote: | Wow Possum! Great demo video.
do not archive |
Can I attach a file to this part of the list without bogging down everyone's computer?
Like this one - I think you would have to open it with "Quicktime"
Jim ODay
Posted: Thu Mar 13, 2008 1:35 pm Post subject: Re: Flying with VGs |
Love your videos so if you would be kind enough to send me it, I use this service below for large files and it is smooth.
https://www.sendthisfile.com
I don't know if large files bog down some Kolbers on the list, probably does. I recall some time ago, some folks had issues with large pics so a video file may be like drinking from a fire hose.
Thanks and fly safe.
Jim
Fargo, ND
Possums
Posted: Fri Mar 14, 2008 2:35 pm Post subject: Flying with VGs |
At 04:00 PM 3/13/2008, you wrote:
Possums,
Could you mount the camera above the wing showing the VG's and then
pour some engine oil on your leading edge and take a flight.
I'm curious how the air is moving around the VG's and where the flow
separation occurs compared to your VG placement.
The oil trails will show what is happening up there. [Wink]
I'd have to wash my plane first - you can see how dusty my wings are.
65.72 KB |
715 Time(s) |
ulflyer(at)verizon.net Guest
Posted: Sat Mar 15, 2008 4:46 pm Post subject: Flying with VGs |
What is the do-dad on you nose cone right in front of you?
Are you using it for slip indicator? First I thought it was a
pivoting airspeed probe like they often use on aircraft during
certification testing.but it looks like it acts more like a ground
direction indicator?
jerb
At 09:30 PM 3/12/2008, you wrote:
beauford173(at)verizon.ne Guest
Posted: Sat Mar 15, 2008 6:10 pm Post subject: Flying with VGs |
jerb
.actully it sorta is, jerb.... when it points directly back at the
Possum, then spins ten or
fifteen times, it means he is firmly emplaced betwen the Posture-Pedic and
the crapper
in the second story master bedroom of that big 'ol house he passed within 30
feet of on
very short final into the Possum Patch in the video... and if he is lucky
it will then swing
yet again to point toward the stairs so he can beat-feet out of the house
before the
authorities show up...
helpful beauford
FF-076
Brandon, FL
Possums
Posted: Sun Mar 16, 2008 6:32 am Post subject: Flying with VGs |
At 08:43 PM 3/15/2008, you wrote:
jerb
Using it as a slip indicator - it came off a sail boat.
A string works just as well if I have my windshield on, but not so good
when I fly out in the open.
Possums
Posted: Sat Mar 22, 2008 5:13 pm Post subject: Re: Flying with VGs |
[quote="jb92563"]Possums,
Love that landing movie....quote]
So .......I'm trying to find out how you can add attachments to this part of the list "Read this topic online here" without affecting the "email" part of the list and forcing people to have to download something they don't choose to?
Got any idea? or "How do you do it"?
biglar
Posted: Sat Mar 22, 2008 5:42 pm Post subject: Flying with VGs |
Only way I know of is to publish it, then put the link in the email to
the List. A regular attachment will open automatically with the message
and cause grief to those on dial up. Not fair to
'em. Lar. Do not Archive.
Possums wrote:
Possum
http://forums.matronics.com/viewtopic.php?p=171827#171827
Larry Bourne
Santa Fe, NM
www.gogittum.com
www.gogittum.com/blog
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
ez(at)embarqmail.com Guest
Posted: Sat Mar 22, 2008 7:25 pm Post subject: Flying with VGs |
Possum,Just sign up for a free Google Gmail account and you will have all the space you need to up load photos, documents, videos and more.
Then you can link it to any email you wish.
Here is an example of a document I just did.
http://docs.google.com/Doc?id=d3jhg27_0fr7x2tcf
On Mar 22, 2008, at 9:13 PM, Possums wrote:[quote] [quote][b]
