gareywittich2000(at)yahoo Guest
Posted: Tue Mar 11, 2008 10:14 am Post subject: Rudder Counter Balance Weight / Rod End Bearings |
Greetings:
1) Have an "older" RUDDER Dwg 7PP which does not show
the how far the 3 Rod End Bearings are suppose to be
screwed into their associated Nut Plates mounted on
the Rudder Spar. What are the dimensions and where
are they measured from ?????
2) Looking at the LEAD COUNTER BALANCE WEIGHT, one of
the 2 pre-drilled holes is closer to the "end" of the
lead weight than the other.
Which Weights "hole" goes forward toward the front of
the rudder AND is the Ribs (R803) tooling hole used to
mount the Lead Weight OR are 2 new holes drilled to
mount the weight ???? Assume the Lead Weight should
be placed as close to the "leading edge"of the Rib
(R803) as possible, is this true ????
Need a little clarification. Thanks, Garey ( Santa
Monica, CA)
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
rv8iator
Posted: Tue Mar 11, 2008 1:23 pm Post subject: Rudder Counter Balance Weight / Rod End Bearings |
Garey...
I started out using the same dimension called out for the horz. stab/elevator. Some adjustment is required upon final assembly after the emp. is mounted to the fuse.
Chris Stone
RV-8 x2
_________________ C. Stone (RV8iator) |
