xl(at)prosody.org Guest
Posted: Thu Mar 06, 2008 10:59 pm Post subject: Overtrimmed airleron |
I've posted a glimpse at
http://www.cleanh2o.com/633z/aileron_hinge_patch.jpg
A repolish is in the queue for the Arlington, WA flyin.
Joe E (at) BFI
CH601XL, 505 hours
On Thu, 7 Feb 2008, ashontz wrote:
Thanks, I appreciate it. I'd like to see you're handywork up close.
xl(at)prosody.org wrote:
> I made the same mistake on both ailerons.
> I didn't see the mistake until I fit ailerons to the wings.
> I took a piece of scrap wide enough to get a rivet in on
> each side. No one has noticed the patch until I point it out.
> (or they've been polite)
> .......snip
> It's the only picture that I can find that shows the patch.
> I see if my camera still works, if it does I'll get a closeup.
>>>> do not archive
japhillipsga(at)aol.com Guest
Posted: Fri Mar 07, 2008 8:32 am Post subject: Overtrimmed airleron |
Dear fellow 601 Builders/Flyers, I may be hijacking this, but is anyone familiar with some posts a couple years ago involving adjusting ailerons down a bit? I seem to remember several flyers were experimenting with drooping them a tad for better control or performance or some reason. Who out there did this and what was the results? For the last year since I stretched my cables in a crosswind balloon landing my XL seems more "twitchy" in climb to TOC. Maybe the ailerons are too high or too tightly adjusted? Hope to hear from some builder/flyers. Thanks, Bill of Georgia
paulrod36(at)msn.com Guest
Posted: Fri Mar 07, 2008 10:05 am Post subject: Overtrimmed airleron |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Bill, are you sure you stretched your cables? As I recall, they have about a 900 pounds-plus capability, which ought to bend structure before breaking. Doesn't seem like a nasty landing ought to do that.
Paul Rodriguez
leo(at)zuehlfield.com Guest
Posted: Fri Mar 07, 2008 12:24 pm Post subject: Overtrimmed airleron |
Bill, On my 601HDS, I placed a dial type level on top of the top
longeron on the side of the cockpit. I originally found I was flying 2
degrees nose high at level normal cruise. I started drooping both
ailerons a 1/2 turn at a time. ( I thought I had them neutral, eyeball
of course) At zero on the level, I picked up _4 MPH_ at cruise. At
negative angles, I again lost speed. I did not detect any change on
control sensitivity at any setting.
Leo Gates
N601Z - CH601hds TDO
Rotax 912UL
japhillipsga(at)aol.com wrote:
| Quote: | Dear fellow 601 Builders/Flyers, I may be hijacking this, but is
Posted: Tue Mar 11, 2008 5:16 am Post subject: Overtrimmed airleron |
Paul, it was one of those "you had to be there" moments. Bill
Posted: Tue Mar 11, 2008 5:23 am Post subject: Overtrimmed airleron |
Leo, thanks for the info. I don't notice the "twitchy" effect in moderate climb (say 500 fpm or less), level flight or decent. Only on initial climb out, max power, nose up scratching for altitude accent. Usually, 1K fpm + (at) 100 mph or better. I know the nose up configuration is decreasing stability, but my AOA LRI is buried in the green so I'm nowhere near a stall. Bill
