BMWBikeCrz(at)aol.com Guest
Posted: Sun Mar 09, 2008 3:49 pm Post subject: Rotax Oil Penzoil |
Anyone running "aircooled" oil in thier watercooled motors I want to use my left over fuel from flying in my outboard motor ...Dave
It's Tax Time! Get tips, forms, and advice on AOL Money & Finance.
(http://money.aol.com/tax?NCID=aolprf00030000000001) [quote][b]
Roger Lee
Posted: Sun Mar 09, 2008 4:43 pm Post subject: Re: Rotax Oil Penzoil |
Won't hurt a thing.
Do you know that Penzoil just relabels some of their products for marketing. No change in actual formula. Talk to the marketing guys and they'll tell you there is a difference. I have talked to the engineer's at Penzoil group and they say BS they just relabeled. And I'm sure if you talk to other people you will hear everything in between.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Sun Mar 09, 2008 5:05 pm Post subject: Rotax Oil Penzoil |
marketing. >
| Quote: | --------
Roger Lee
Which products and what new labels?
_________________ John Hauck
Titus, Alabama |
Thom Riddle
Posted: Mon Mar 10, 2008 3:44 am Post subject: Rotax Oil Penzoil |
Roger,
Pennzoil CHANGED THE NAME(and thus the label) of the 2-stroke oil for
air cooled engines to something with "outdoor" in it. They DO NOT have
a single oil formulation being currently sold with two different
names! Your statement that they are simply relabeling is misleading.
Also, the 912ul engine compression ratio is 9.0:1 not 8.5:1.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Mon Mar 10, 2008 4:07 am Post subject: Rotax Oil Penzoil |
At 07:42 AM 3/10/2008, Thom Riddle wrote:
| Quote: | Pennzoil CHANGED THE NAME(and thus the label) of the 2-stroke oil for
They changed the name of the "air cooled 2-stroke" oil to "outdoor", but
the "watercooled" product is/was something different. Whether it's
_really_ anything different I don't know, but it would make sense that the
formulation would be different for an outboard engine running at lower
temperatures (cooled as it is by a steady supply of cold water) as opposed
to an aircooled engine running at higher temperatures.
Either way, I would think that the air cooled ("outdoor") oil would be a
better choice for a water cooled Rotax since the operating conditions are
closer to those of an air cooled engine than an outboard. When you think
about it, a watercooled Rotax on a plane IS air cooled... just indirectly.
-Dana
Scientists cause cancer in laboratory animals.
rowedenny
Roger Lee
Posted: Mon Mar 10, 2008 12:55 pm Post subject: Re: Rotax Oil Penzoil |
Hi Thom,
According to the marketing guys you get on the phone you are 100%right. They make everything special. Talk to the engineers behind those guys down in the trenches and get a different story. I heard it both ways when I did an oil study 5 years ago. I never talk to marketers on a phone anymore. They only tell you what they were told or is written in front of them. I got burned once or twice and have learned to dig deeper past the hype.
I believe I had corrected that post for 9:1 compression within a minute of posting. I checked it, it still reads 9:1.
Some oils used around water do have a different additive package.
Tucson, Az.
Cell 520-349-7056
jim
Posted: Mon Mar 10, 2008 12:58 pm Post subject: Re: Rotax Oil Penzoil |
I don't think you'd have any problems running the Pennzoil "Aircooled" 2 stroke oil in an outboard. The Aircooled product is made to lubricate under the much tougher conditions (i.e. higher temps) of aircooled engines, such as chainsaws, weedwackers, etc.
_________________ Jim
N. Idaho |
Dana
Posted: Mon Mar 10, 2008 1:55 pm Post subject: Rotax Oil Penzoil |
At 04:58 PM 3/10/2008, jim wrote:
| Quote: | I don't think you'd have any problems running the Pennzoil "Aircooled" 2
Not saying it's the case here, I really don't know, but I can visualize an
oil formulated for the higher temperatures of an air cooled engine sludging
or carboning up in a cooler running water cooled outboard... or an oil
formulated for a cooler running not lubricating as well in a hotter engine.
-Dana
Don't steal. The IRS hates competition.
Steve Boetto
Posted: Mon Mar 10, 2008 2:18 pm Post subject: Rotax Oil Penzoil |
Pennzoil® Multi-Purpose 2-Cycle Premium Engine Oil
[img]http://www.pennzoil.com/products/outdoor/images/Premium-Outboard-&-Multi-P.jpg[/img]
A high performance 2-cycle engine oil meeting or exceeding the warranty requirements of all leading manufacturers of 2-cycle products including chain saws, lawn mowers, motorcycles and string trimmers, as well as outboard engines made by: Johnson/Evinrude, Mercury Marine, Yamaha, Suzuki, Nissan, Force/US Marine, Mariner, Sears and all other manufacturers requiring NMMA TC-W3® oil.
Pennzoil ® Multi-Purpose 2-Cycle Premium Engine Oil is formulated to: - Protect against piston scuffing and ring sticking.
- Help keep spark plugs and exhaust ports clean.
Recommended for pre-mix, injector systems and direct injection systems. Good for water-cooled and air-cooled 2-cycle engines recommending NMMA TC-W3 ® products. Always follow the dilution ratio and oil performance level recommended in the owner’s manual. For any use where NMMA TC-W3®, TC-W II® or TC-W® oil is recommended
ates such e, gt; - MATRONICS WEB FORUMS -
-> p; - List Contribution Web Site =========================
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Steve Boetto
Posted: Mon Mar 10, 2008 2:24 pm Post subject: Rotax Oil Penzoil |
In a message dated 3/10/2008 6:18:51 P.M. Eastern Daylight Time, N27SB(at)aol.com writes:
| Quote: | | Good for water-cooled and air-cooled 2-cycle engines |
Dana
Posted: Mon Mar 10, 2008 2:32 pm Post subject: Rotax Oil Penzoil |
Hmmm, makes me wonder if the new "Outdoor" oil (whether or not it's the oil that's new or just the packaging) is intended to replace both their "air cooled" and their "outboard" oil.
'Course I knew some guys that used nothing but generic TC-W3 oil from West Marine in the 503 on their Quick with no troubles that I know of.
-Dana
At 06:15 PM 3/10/2008, N27SB(at)aol.com wrote:
| Quote: | [img]cid:5.1.0.14.2.20080310182212.00c24010(at)mail.comcast.net.0[/img]Pennzoil Multi-Purpose 2-Cycle Premium Engine Oil..
A high performance 2-cycle engine oil meeting or exceeding the warranty requirements of all leading manufacturers of 2-cycle products including chain saws, lawn mowers, motorcycles and string trimmers, as well as outboard engines made by: Johnson/Evinrude, Mercury Marine, Yamaha, Suzuki, Nissan, Force/US Marine, Mariner, Sears and all other manufacturers requiring NMMA TC-W3... |
| Description: |
| Filesize: |
7.64 KB |
| Viewed: |
12216 Time(s) |
lucien
Posted: Mon Mar 10, 2008 7:04 pm Post subject: Re: Rotax Oil Penzoil |
| Dana wrote: | Hmmm, makes me wonder if the new "Outdoor" oil (whether or not it's the oil that's new or just the packaging) is intended to replace both their "air cooled" and their "outboard" oil.
-Dana
Look at the API spec on the bottle, that'll tell you which oil grade you have. The TCW-III grade is primarily a standard for lubricating water-cooled 2 strokes. API TC grade is a tougher standard intended for lubing air-cooled motors.
The TCW-III spec does specify a miniimum lubrication ability for air-cooled engines, tho, so it will work fine in an air-cooled engine as well. It's not as stringent as the TC spec tho...
LS
_________________ LS
Titan II SS |
