Rotax Oil Penzoil
BMWBikeCrz(at)aol.com
PostPosted: Sun Mar 09, 2008 3:49 pm    Post subject: Rotax Oil Penzoil Reply with quote
Anyone running "aircooled" oil in thier watercooled motors I want to use my left over fuel from flying in my outboard motor ...Dave
It's Tax Time! Get tips, forms, and advice on AOL Money & Finance.
(http://money.aol.com/tax?NCID=aolprf00030000000001) [quote][b]
Roger Lee
PostPosted: Sun Mar 09, 2008 4:43 pm    Post subject: Re: Rotax Oil Penzoil Reply with quote
Won't hurt a thing.
Do you know that Penzoil just relabels some of their products for marketing. No change in actual formula. Talk to the marketing guys and they'll tell you there is a difference. I have talked to the engineer's at Penzoil group and they say BS they just relabeled. And I'm sure if you talk to other people you will hear everything in between.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
PostPosted: Sun Mar 09, 2008 5:05 pm    Post subject: Rotax Oil Penzoil Reply with quote
marketing. >
Roger Lee
Which products and what new labels?
Thom Riddle
PostPosted: Mon Mar 10, 2008 3:44 am    Post subject: Rotax Oil Penzoil Reply with quote
Roger,
Pennzoil CHANGED THE NAME(and thus the label) of the 2-stroke oil for
air cooled engines to something with "outdoor" in it. They DO NOT have
a single oil formulation being currently sold with two different
names! Your statement that they are simply relabeling is misleading.
Also, the 912ul engine compression ratio is 9.0:1 not 8.5:1.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dana
PostPosted: Mon Mar 10, 2008 4:07 am    Post subject: Rotax Oil Penzoil Reply with quote
They changed the name of the "air cooled 2-stroke" oil to "outdoor", but
the "watercooled" product is/was something different. Whether it's
_really_ anything different I don't know, but it would make sense that the
formulation would be different for an outboard engine running at lower
temperatures (cooled as it is by a steady supply of cold water) as opposed
to an aircooled engine running at higher temperatures.
Either way, I would think that the air cooled ("outdoor") oil would be a
better choice for a water cooled Rotax since the operating conditions are
closer to those of an air cooled engine than an outboard. When you think
about it, a watercooled Rotax on a plane IS air cooled... just indirectly.
-Dana
Scientists cause cancer in laboratory animals.
rowedenny
PostPosted: Mon Mar 10, 2008 11:57 am    Post subject: Rotax Oil Penzoil Reply with quote
Dave,
I run Penzoil air cooled in my 2SI 690L-70 and it likes it. Smile
Dennis Rowe
Roger Lee
PostPosted: Mon Mar 10, 2008 12:55 pm    Post subject: Re: Rotax Oil Penzoil Reply with quote
Hi Thom,
According to the marketing guys you get on the phone you are 100%right. They make everything special. Talk to the engineers behind those guys down in the trenches and get a different story. I heard it both ways when I did an oil study 5 years ago. I never talk to marketers on a phone anymore. They only tell you what they were told or is written in front of them. I got burned once or twice and have learned to dig deeper past the hype.
I believe I had corrected that post for 9:1 compression within a minute of posting. I checked it, it still reads 9:1.
Some oils used around water do have a different additive package.
Roger Lee
Tucson, Az.
Cell 520-349-7056
jim
PostPosted: Mon Mar 10, 2008 12:58 pm    Post subject: Re: Rotax Oil Penzoil Reply with quote
I don't think you'd have any problems running the Pennzoil "Aircooled" 2 stroke oil in an outboard. The Aircooled product is made to lubricate under the much tougher conditions (i.e. higher temps) of aircooled engines, such as chainsaws, weedwackers, etc.
Jim
N. Idaho
Dana
PostPosted: Mon Mar 10, 2008 1:55 pm    Post subject: Rotax Oil Penzoil Reply with quote
Not saying it's the case here, I really don't know, but I can visualize an
oil formulated for the higher temperatures of an air cooled engine sludging
or carboning up in a cooler running water cooled outboard... or an oil
formulated for a cooler running not lubricating as well in a hotter engine.
-Dana
Don't steal. The IRS hates competition.
Steve Boetto
PostPosted: Mon Mar 10, 2008 2:18 pm    Post subject: Rotax Oil Penzoil Reply with quote
Pennzoil® Multi-Purpose 2-Cycle Premium Engine Oil
[img]http://www.pennzoil.com/products/outdoor/images/Premium-Outboard-&-Multi-P.jpg[/img]
A high performance 2-cycle engine oil meeting or exceeding the warranty requirements of all leading manufacturers of 2-cycle products including chain saws, lawn mowers, motorcycles and string trimmers, as well as outboard engines made by: Johnson/Evinrude, Mercury Marine, Yamaha, Suzuki, Nissan, Force/US Marine, Mariner, Sears and all other manufacturers requiring NMMA TC-W3® oil.
Pennzoil ® Multi-Purpose 2-Cycle Premium Engine Oil is formulated to:
  • Protect against piston scuffing and ring sticking.
  • Help keep spark plugs and exhaust ports clean.
Recommended for pre-mix, injector systems and direct injection systems. Good for water-cooled and air-cooled 2-cycle engines recommending NMMA TC-W3 ® products. Always follow the dilution ratio and oil performance level recommended in the owner’s manual. For any use where NMMA TC-W3®, TC-W II® or TC-W® oil is recommended
ates such e, gt; - MATRONICS WEB FORUMS -
-> p; - List Contribution Web Site =========================
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Steve Boetto
PostPosted: Mon Mar 10, 2008 2:24 pm    Post subject: Rotax Oil Penzoil Reply with quote
In a message dated 3/10/2008 6:18:51 P.M. Eastern Daylight Time, N27SB(at)aol.com writes:
Dana
PostPosted: Mon Mar 10, 2008 2:32 pm    Post subject: Rotax Oil Penzoil Reply with quote
Hmmm, makes me wonder if the new "Outdoor" oil (whether or not it's the oil that's new or just the packaging) is intended to replace both their "air cooled" and their "outboard" oil.
'Course I knew some guys that used nothing but generic TC-W3 oil from West Marine in the 503 on their Quick with no troubles that I know of.
-Dana
At 06:15 PM 3/10/2008, N27SB(at)aol.com wrote:
[img]cid:5.1.0.14.2.20080310182212.00c24010(at)mail.comcast.net.0[/img]Pennzoil Multi-Purpose 2-Cycle Premium Engine Oil..
A high performance 2-cycle engine oil meeting or exceeding the warranty requirements of all leading manufacturers of 2-cycle products including chain saws, lawn mowers, motorcycles and string trimmers, as well as outboard engines made by: Johnson/Evinrude, Mercury Marine, Yamaha, Suzuki, Nissan, Force/US Marine, Mariner, Sears and all other manufacturers requiring NMMA TC-W3...
 Filesize:  7.64 KB
 Viewed:  12298 Time(s)
lucien
PostPosted: Mon Mar 10, 2008 7:04 pm    Post subject: Re: Rotax Oil Penzoil Reply with quote
-Dana
Look at the API spec on the bottle, that'll tell you which oil grade you have. The TCW-III grade is primarily a standard for lubricating water-cooled 2 strokes. API TC grade is a tougher standard intended for lubing air-cooled motors.
The TCW-III spec does specify a miniimum lubrication ability for air-cooled engines, tho, so it will work fine in an air-cooled engine as well. It's not as stringent as the TC spec tho...
LS
LS
Titan II SS
