rickpegser(at)yahoo.com Guest
Posted: Sat Mar 15, 2008 10:22 pm Post subject: FUEL LEAK FIX |
Tank leaks can be a bitch to find and worse to fix. but the nice thing is that prc 1422 can hide a lot of sins. a scotch bright pad on a die grinder will clean up any flange. Don't worry about the alclad you will bury it in sealant. call me i will walk you through the repair. there are several ways to do this based upon what you have available. the RV tank did not use the right nut plate for fuel tank, IE. domed.
rick m
a+p/i+a
559-270-7113
Be a better friend, newshound, and [quote][b]
