jcz(at)chello.at Guest
Posted: Mon Mar 10, 2008 7:02 am Post subject: AW: Re: Trailering my KitfoxRe: Trailering my Kitfox |
.... Any Suggestions? Yes, sure: Add a fuselage support to your trailer - two uprights with a hole in each aligning with the fuselage crosstube situated about a foot in front of the rudder, originally meant to attach a towbar. A long bolt through here will take all the load off the tailwheel spring, plus eliminating the need to think up a way to tie down the tailwheel. You should never, repeat N-E-V-E-R trailer a Kitfox without this, not even for short distances and slow speeds!
Johannes Von: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] Im Auftrag von Chuck Popenoe
Gesendet: Montag, 10. März 2008 15:36
An: kitfox-list(at)matronics.com
Betreff: Re: Re: Trailering my KitfoxRe: Trailering my Kitfox
... But, that pales by comparison with what would happen if the spring broke while trailering at highway speed! I hadn’t considered that possibility! Any suggestions??
Pops
Checked by AVG.
3/10/2008 11:07 AM
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Lynn Matteson
Posted: Mon Mar 10, 2008 8:36 am Post subject: AW: Re: Trailering my KitfoxRe: Trailering my Kitfox |
Amen, Johannes...you took the words right out of my mouth. But not to
worry, there's a lot of other words left in there, so I'm not in
danger of running out. ; )
Lynn Matteson
flying w/475+ hrs
On Mar 10, 2008, at 10:59 AM, Johannes Czernin wrote:
| Quote: | .... Any Suggestions? Yes, sure: Add a fuselage support to your
JohannesVon: owner-kitfox-list-server(at)matronics.com [mailto:owner-
Kitfox
Pops
Checked by AVG.
3/10/2008 11:07 AM
forums.matronics.comhref="http://www.matronics.com/
contribution">http://www.matronics.com/c_-
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
