dan(at)rdan.com Guest
Posted: Wed Mar 01, 2006 12:45 am Post subject: Quick rv7 rudder question |
David,
I'm on an -8 just starting the Rudder it used different spar and rib part numbers but if it's the top tip rib, on the 8 it uses AN470AD4-4
not sure if it the same on a 7
Dan
-8 Rudder
David Karlsberg <claypride(at)hotmail.com> wrote:
So I looked for what seemed to be like forever and cannot figure out what
type of rivet is used to connect R-912 (the counter balance rib) to R-902
(spar) anybody have the drawings handy?
David Karlsberg
Rudder -7
truflite(at)yahoo.com Guest
Posted: Wed Mar 01, 2006 6:54 am Post subject: Quick rv7 rudder question |
I had that same question when I built my rudder not
that long ago. I could not find an answer. So, I
went back to basics. I knew that I needed 1.5 times
the diameter of the rivet protruding from the shop
side. I therefore took some different length AN470AD4
rivets and fit each one till I found one that looked
to be about 1.5 times as long as the diameter. If you
are getting specific, you need .140 sticking out.
Dave
--- David Karlsberg <claypride(at)hotmail.com> wrote:
David Karlsberg
Rudder -7
browse
Subscriptions page,
FAQ,
Admin.
