Dog67(at)aol.com Guest
Posted: Tue Mar 04, 2008 10:44 am Post subject: RV-7 Holy Cowl plenum |
Anyone have any experience using a 'Holy Cowl' plenum on an RV-7? I'm interested in ease of use, performance, cooling, etc.
Jon Apfelbaum, SLC, UT
Slowly building an RV-7
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
frank.hinde(at)hp.com Guest
Posted: Tue Mar 04, 2008 11:05 am Post subject: RV-7 Holy Cowl plenum |
Yup I got one, the long cowl with a prop extension swinging a heavy Hartzell C/S prop.
I do aerobatics with it too.
Two of my friends also have them one is flying
Seem to be a little faster than a standard RV in a side by side flyoff..Cooling works great.
Its a little more work than a Vans cowl, mainly because of the plenum.
Looks hot though!
Frank
Rv7a 260 hours
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dog67(at)aol.com
Sent: Tuesday, March 04, 2008 10:41 AM
To: rv7-list(at)matronics.com
Subject: RV-7 Holy Cowl plenum
ics.com
.matronics.com/contribution
garrys(at)tampabay.rr.com Guest
Posted: Tue Mar 04, 2008 12:32 pm Post subject: RV-7 Holy Cowl plenum |
I have the Sam James cowls and plenum on my RV-7A. Cooling is not an issue under any conditions, and they look great. I don't think they're any faster than stock, but then I have nothing to compare against. The install effort might be a tad more, but basically the same effort.
Garry Stout
Tampa Fl
dhall(at)donka.net Guest
Posted: Tue Mar 04, 2008 5:05 pm Post subject: RV-7 Holy Cowl plenum |
I was turned off by the rqmt for prop extension. I thought that limited aerobatic use, so curious to hear that it does not.
I******************************************
Don Hall
N517DG (registered)
rv7 finishing
Sent: Tuesday, March 04, 2008 1:41 PM
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List
Posted: Tue Mar 04, 2008 6:20 pm Post subject: RV-7 Holy Cowl plenum |
Well its like evrything else in flying...I.e how hard are you going to do it?
One thing I learned is this airplane is not an Extra 300 or a Pitts...It simply will not do hardore aerobatics...By that I mean the only reason to pull high is cus you screwed something up.
So far I have logged +5 and -ve 2.3 G's...and that was while attempting an inverted spin...which it oes not like to do. and this airplane will really not do gyroscopic manouvers.
In my reasearch I i discovered that this really is an airplane that will do everything within 3.5 to 4 Gs...As the extended hub prop is limited to _/- 4Gs its really not an issue.
If you would like to see the acro I do look in "youtube.com" and sarch under "rv aerobatics"...I have put three vids up there under my user name "frank hinde"
Enjoy
Frank
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Don Hall
Sent: Tuesday, March 04, 2008 5:03 PM
Subject: RE: RV-7 Holy Cowl plenum
Don Hall
N517DG (registered)
rv7 finishing
ics.com
jason.rouault(at)hp.com Guest
Posted: Wed Mar 05, 2008 6:13 am Post subject: RV-7 Holy Cowl plenum |
Some props have built in hub extensions with zero acro limitations. My MT 3 Blade is one of them.
Jason
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis)
Sent: Tuesday, March 04, 2008 7:17 PM
Enjoy
Frank
Don Hall
N517DG (registered)
rv7 finishing
| Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c ://www.matronics.com/Navigator?RV7-Listics.com.matronics.com/contribution | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 4 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 5 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 6 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 7 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 8 | Quote: | | href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List | 9 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 0
