RV Crash
panamared5(at)brier.net
PostPosted: Mon Mar 03, 2008 8:00 am    Post subject: RV Crash Reply with quote
I learned about this from the IAC Arco list. Any more news from the
RV fliers in the area?
Bob
RV6 "Wicked Witch of the West"
"I was informed that Phil Schadt ( sp ?) was Killed today in an RV
inFL... FOXNEWS.com has more info. He was taxiing in to a pancake
breakfast and another a/c landed on his machine...Both in his a/c were killed."
ronlee(at)pcisys.net
PostPosted: Mon Mar 03, 2008 8:39 am    Post subject: RV Crash Reply with quote
Bob
Go to vanairforce and there is a thread there with an eyewitness account.
The RV guys apparently had no chance to escape their fate.
Ron Lee
sbuc(at)hiwaay.net
PostPosted: Mon Mar 03, 2008 8:57 am    Post subject: RV Crash Reply with quote
Bob wrote:
I learned about this from the IAC Arco list. Any more news from the RV
fliers in the area?
Quite a bit of info with links to local news video on the VAF forum.
Three confirmed fatalities at this point. Very sad.
Sam Buchanan
pitts_pilot(at)bellsouth.
PostPosted: Mon Mar 03, 2008 2:07 pm    Post subject: RV Crash Reply with quote
Bob
killed."
Our flight to Arthur Dunn was diverted because the airport was closed.
Chuck Durbeck from X59 took the attached pictures. I didn't read the
VAF account, so some may be wrong info. The Velocity was landing behind
other aircraft and was overrunning aircraft on the runway. The velocity
initiated a go-around, but was unsuccessful, left the runway on the
right side and clipped the RV-8 that was on the exit taxiway. the wing
from the Velocity sliced through the cockpit of the RV8, which is where
the occuppants died. The Velocity continued in the grass between the
runway and parallel taxiway, coming to rest inverted, and on fire. Both
occupants of the Velocity were severely burned, and the passenger
succomed in the hospital. the last word I have is that the pilot (from
Sebastian, FL) is still alive in critical condition. Truly a sad day,
indeed.
Linn
 Filesize:  20.5 KB
 Viewed:  454 Time(s)
 Filesize:  20.36 KB
 Viewed:  470 Time(s)
 Filesize:  20.51 KB
 Viewed:  480 Time(s)
n395v
PostPosted: Tue Mar 04, 2008 5:43 am    Post subject: Re: RV Crash Reply with quote
http://www.vansairforce.com/community/showthread.php?t=27399
Milt
