powder coating little parts
airspeedx3(at)yahoo.com
PostPosted: Sun Mar 02, 2008 6:51 am    Post subject: powder coating little parts Reply with quote
Kolb group,
Good morning. I was wondering if anyone has ever tried using one of those inexpensive
"powdercoat at home" things? I have seen them advertized for about $50, and then you buy the
powder color you want. Thank you for your help.
Dudley
Building a MkIII
Be a better friend, newshound, and [quote][b]
planecrazzzy
PostPosted: Sun Mar 02, 2008 7:55 am    Post subject: Re: powder coating little parts Reply with quote
The trick isn't putting it on....it's "curing" it. ( 400 degrees/20 min ? )
You don't wanna use yer house oven.
Gotta Fly...
Mike & "Jaz" in MN - FSII / White Epoxy
 Filesize:  60.23 KB
 Viewed:  736 Time(s)
mdnanwelch7(at)hotmail.co
PostPosted: Sun Mar 02, 2008 8:20 am    Post subject: powder coating little parts Reply with quote
Nope, don't want to use the wife's house oven, again. Did that with some fiberglass parts I was trying to cure in a hurry. (non-flying stuff parts...halloween mask, caught on fire, bad idea, anyway, forget the house oven idea.) Too much smoke!! (the halloween mask came out kind of scary, with all the burn marks!!)
But, I HAVE heard using a propane grill can work very well. Yes, it WILL get to 400 degrees. And, according to what I heard, the propane's heat is very good on the powder-paint. Just suspend the pieces, crank it to high, watch the temp gauge and the timer.
Of course, a guy could pick up a cheapo electric oven at a surplus yard. It doesn't have to look very good, just heat fairly accurately.
I guess the main question I had is if anyone owns one of these low budget powdercoat kits, or, as usual, they're just crap, and you get what you pay for, like always.
Mike Welch
Subject: Re: powder coating little parts
Date: Sun, 2 Mar 2008 07:55:34 -0800
Gotta Fly...
http://forums.matronics.com/viewtopic.php?p=167246#167246
http://forums.matronics.com//files/finished_upholstery_141.jpg
Shed those extra pounds with MSN and The Biggest Loser!
http://biggestloser.msn.com/
herbgh(at)nctc.com
PostPosted: Sun Mar 02, 2008 9:08 am    Post subject: powder coating little parts Reply with quote
Justa guess Mike---but if you take a lot of little parts to a coater
and tell him any color but pink; then he might give you a break as he
could include them in with bigger , better paying jobs ? Frugal Herb
Mike Welch
> From: planecrazzzy(at)yahoo.com
> To: kolb-list(at)matronics.com
> Gotta Fly...
> Do Not Archive
captainron1(at)cox.net
PostPosted: Sun Mar 02, 2008 10:20 am    Post subject: powder coating little parts Reply with quote
I powder coated my cage, later I discovered the wonderful world of epoxy two part paints. If I were to do it again the two part epoxy primer would be my choice. That is one tough coating, like glue and paint in one. Very resistant to everything and strong.
Ron
Gotta Fly...
JetPilot
PostPosted: Sun Mar 02, 2008 11:01 am    Post subject: Re: powder coating little parts Reply with quote
Which two part primer and paint did you have such good results with Ron ? I see several of them advertised, but don't know which one is best.
Mike
Kolb MK-III Xtra, 912-S
biglar
PostPosted: Sun Mar 02, 2008 12:14 pm    Post subject: powder coating little parts Reply with quote
I had very good results with the 2 part white paint, too, and it's easy
to repair. Seems like I got mine from Jim &
Dondi. Lar.
Mike
&quot;NO FEAR&quot; - If you have no fear you did not go as fast as you could have !!!
http://forums.matronics.com/viewtopic.php?p=167281#167281
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
PostPosted: Sun Mar 02, 2008 4:03 pm    Post subject: powder coating little parts Reply with quote
This is horrible but I can't remember the Manufacturer. I can see it in my mind's eye exactly where the cans sit on my work table 1200 miles away from here, but can't remember the name. However a few years ago we spoke about powder coating and I did name the epoxy. Somewhere in the library there is a mention of that manufacturer. I can say this, if you leave the crap in one of those little clear plastic cups it will melt it. Its some strong stuff and you ought to use a respirator, I do.
Ron (Txaz)
Mike
kugelair.com
HShack(at)aol.com
PostPosted: Sun Mar 02, 2008 6:41 pm    Post subject: powder coating little parts Reply with quote
A friend has one; does good on small parts.
Howard Shackleford
FS II
SC
In a message dated 3/2/2008 9:52:14 A.M. Eastern Standard Time, airspeedx3(at)yahoo.com writes:
Kolb group,
Dudley
Building a MkIII
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
