checkpoint2(at)comcast.ne Guest
Posted: Thu Feb 28, 2008 5:27 am Post subject: JabiruEngine-List Digest: 3 Msgs - 02/27/08 |
Any one, is there an alternator suitable for the 2200 that fits on
The rear drive pad? BH N 380 BH.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
andy(at)suncoastjabiru.co Guest
Posted: Fri Feb 29, 2008 2:40 pm Post subject: JabiruEngine-List Digest: 3 Msgs - 02/27/08 |
Be careful with any add-on alternator which goes directly on the back of the
crankshaft; they are really designed for the accessory pad on LYC/Cont.
engines where the rpms are much higher through gearing. If the add-on
alternator is rated at (say) 40 amps, ask what rpm that's for, and it'll
probably be well over 3000. The Jabiru will be turning mostly between 2700
and 2900 in cruise, but amps will probably drop right off below that. Others
here on the list have had success with belt-driven supplementary power, but
it's not as simple or as light as a bolt-on job. Hope this helps.
Andy
www.suncoastjabiru.com
Posted: Sun Mar 02, 2008 5:52 am Post subject: JabiruEngine-List Digest: 3 Msgs - 02/27/08 |
Hey Andy! Thanks for the advice, I had planned to get the output
Rpm on the alternator be fore I leaped off the cliff! I have been
Planning to come up your way soon, but you know how that works, Bob.
